주요 콘텐츠로 건너뛰기
Aquarium CO2 System Replacement
필요한 것
  1. Aquarium CO2 System Replacement, CO2 System: 1 단계, 이미지 1개 중 1개
    • Using the funnel, pour 1 teaspoon of baking soda, 7 tablespoons of sugar, 2 cups of lukewarm water, and 2 teaspoons of yeast into the 2L empty bottle.
  2. Aquarium CO2 System Replacement: 2 단계, 이미지 1개 중 1개
    • Close the bottle.
    • Shake the bottle rapidly for 15 seconds (or until the liquid has turned milky-white).
  3. Aquarium CO2 System Replacement: 3 단계, 이미지 3개 중 1개 Aquarium CO2 System Replacement: 3 단계, 이미지 3개 중 2개 Aquarium CO2 System Replacement: 3 단계, 이미지 3개 중 3개
    • Poke, drill, or cut a small hole in a 2L bottle cap and insert an airline tubing adaptor.
    • Use some kind of glue or sealant to seal the top of the bottle cap, ensuring an airtight fit.
    • Connect one end of the airline tubing to the airline tubing adapter, and the other end of the airline tubing to the CO2 diffuser.
  4. Aquarium CO2 System Replacement: 4 단계, 이미지 1개 중 1개
    • Seal the bottle with the airline tubing adapter by screwing it onto the top of bottle's open lid.
  5. Aquarium CO2 System Replacement: 5 단계, 이미지 1개 중 1개
    • Place the CO2 diffuser on the inside of the aquarium tank at below half-depth of the water-level.
    • Most CO2 diffusers are able to be stuck to the inside glass of the tank to achieve stronger stability.
    • Make sure the bottle is not placed too far away from the aquarium tank as to avoid any accidents or tears with the airline tubing.
결승점
작성자
2다른 기여자 명과 함께
Aryan Haghighi
회원 가입일: 01/11/21
121 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 1
전체 시간: 165
