주요 콘텐츠로 건너뛰기
Aquarium Top Filter Box Replacement
필요한 것
  1. Aquarium Top Filter Box Replacement, Aquarium Filter Box: 1 단계, 이미지 1/2 Aquarium Top Filter Box Replacement, Aquarium Filter Box: 1 단계, 이미지 2/2
    • Using a black sharpie marker, mark the box for accurate holes.
    • Make sure the hole is a little bit smaller than the soft PVC pipe.
  2. Aquarium Top Filter Box Replacement: 2 단계, 이미지 1/2 Aquarium Top Filter Box Replacement: 2 단계, 이미지 2/2
    • Use the utility knife to cut a hole in the marked position to attach the pipe.
    • Be very careful as the box is difficult to cut.
  3. Aquarium Top Filter Box Replacement: 3 단계, 이미지 1/2 Aquarium Top Filter Box Replacement: 3 단계, 이미지 2/2
    • Using the same utility knife, make a hole in the bottom of the plastic box for the water to come out.
  4. Aquarium Top Filter Box Replacement: 4 단계, 이미지 1/1
    • Attach the soft PVC pipe with the aquarium powerhead.
    • Make sure it is properly connected.
  5. Aquarium Top Filter Box Replacement: 5 단계, 이미지 1/2 Aquarium Top Filter Box Replacement: 5 단계, 이미지 2/2
    • Insert the soft PVC pipe in the plastic box.
  6. Aquarium Top Filter Box Replacement: 6 단계, 이미지 1/3 Aquarium Top Filter Box Replacement: 6 단계, 이미지 2/3 Aquarium Top Filter Box Replacement: 6 단계, 이미지 3/3
    • With a telfon tape properly wrap the soft PVC pipe for no leakage of water.
  7. Aquarium Top Filter Box Replacement: 7 단계, 이미지 1/3 Aquarium Top Filter Box Replacement: 7 단계, 이미지 2/3 Aquarium Top Filter Box Replacement: 7 단계, 이미지 3/3
    • Use aquarium-safe silicone glue to seal the soft PVC pipe with the plastic box.
    • Make sure to let the silicone glue dry for 30 minutes.
  8. Aquarium Top Filter Box Replacement: 8 단계, 이미지 1/3 Aquarium Top Filter Box Replacement: 8 단계, 이미지 2/3 Aquarium Top Filter Box Replacement: 8 단계, 이미지 3/3
    • Add your desired filter media best suited for your aquarium.
    • Finally, submerge the waterpump in water and adjust the waterflow.
    • Be careful were you place the inlet of the filter, so no organisms or substrate get sucked in and die inside or clog it. If needed you can put some filter floss or a sponge on the inlet to prevent the above.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Seaaf
회원 가입일: 05/12/21
181 평판
안내서 1개 작성함
York University, Team S1-G12, Melo-Thaiss Summer 2021 York University, Team S1-G12, Melo-Thaiss Summer 2021 회원
YORK-MELO-THAISS-SU21S1G12
1 회원
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 21
전체 시간: 975
