주요 콘텐츠로 건너뛰기
Aquasana F-300R 300,000 Gallon Whole House Water Filtration System 20-Inch Sediment Pre-Filter Replacement
필요한 것
  1. Aquasana F-300R 300,000 Gallon Whole House Water Filtration System 20-Inch Sediment Pre-Filter Replacement, 20-inch Sediment Pre-Filter: 1 단계, 이미지 2개 중 1개 Aquasana F-300R 300,000 Gallon Whole House Water Filtration System 20-Inch Sediment Pre-Filter Replacement, 20-inch Sediment Pre-Filter: 1 단계, 이미지 2개 중 2개
    • Turn off the water supply by turning the water valve(s) to be horizontal, or perpendicular to the water pipe.
    • You may have one or two valves depending on the installation of your system.
  2. Aquasana F-300R 300,000 Gallon Whole House Water Filtration System 20-Inch Sediment Pre-Filter Replacement: 2 단계, 이미지 1개 중 1개
    • Press the black pressure release button on top of the filter housing.
    • Hold the button down for 5 seconds.
  3. Aquasana F-300R 300,000 Gallon Whole House Water Filtration System 20-Inch Sediment Pre-Filter Replacement: 3 단계, 이미지 3개 중 1개 Aquasana F-300R 300,000 Gallon Whole House Water Filtration System 20-Inch Sediment Pre-Filter Replacement: 3 단계, 이미지 3개 중 2개 Aquasana F-300R 300,000 Gallon Whole House Water Filtration System 20-Inch Sediment Pre-Filter Replacement: 3 단계, 이미지 3개 중 3개
    • Unscrew the filter housing canister clockwise with a water filter housing wrench.
  4. Aquasana F-300R 300,000 Gallon Whole House Water Filtration System 20-Inch Sediment Pre-Filter Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the dirty pre-filter and dispose of it.
  5. Aquasana F-300R 300,000 Gallon Whole House Water Filtration System 20-Inch Sediment Pre-Filter Replacement: 5 단계, 이미지 3개 중 1개 Aquasana F-300R 300,000 Gallon Whole House Water Filtration System 20-Inch Sediment Pre-Filter Replacement: 5 단계, 이미지 3개 중 2개 Aquasana F-300R 300,000 Gallon Whole House Water Filtration System 20-Inch Sediment Pre-Filter Replacement: 5 단계, 이미지 3개 중 3개
    • Wash the filter housing canister with dish soap and water.
    • You may need a long-handled cleaning brush to scrub off dirt and debris.
    • Rinse and dry the filter housing canister.
  6. Aquasana F-300R 300,000 Gallon Whole House Water Filtration System 20-Inch Sediment Pre-Filter Replacement: 6 단계, 이미지 1개 중 1개
    • Remove the O-ring from the housing canister.
  7. Aquasana F-300R 300,000 Gallon Whole House Water Filtration System 20-Inch Sediment Pre-Filter Replacement: 7 단계, 이미지 1개 중 1개
    • Clean off old grease on the O-ring with a towel.
  8. Aquasana F-300R 300,000 Gallon Whole House Water Filtration System 20-Inch Sediment Pre-Filter Replacement: 8 단계, 이미지 2개 중 1개 Aquasana F-300R 300,000 Gallon Whole House Water Filtration System 20-Inch Sediment Pre-Filter Replacement: 8 단계, 이미지 2개 중 2개
    • Replace the O-ring.
    • Apply Vaseline or lube around the seal.
  9. Aquasana F-300R 300,000 Gallon Whole House Water Filtration System 20-Inch Sediment Pre-Filter Replacement: 9 단계, 이미지 2개 중 1개 Aquasana F-300R 300,000 Gallon Whole House Water Filtration System 20-Inch Sediment Pre-Filter Replacement: 9 단계, 이미지 2개 중 2개
    • Place the new pre-filter in the center of the filter housing canister.
  10. Aquasana F-300R 300,000 Gallon Whole House Water Filtration System 20-Inch Sediment Pre-Filter Replacement: 10 단계, 이미지 2개 중 1개 Aquasana F-300R 300,000 Gallon Whole House Water Filtration System 20-Inch Sediment Pre-Filter Replacement: 10 단계, 이미지 2개 중 2개
    • Screw the filter housing canister counter-clockwise with your hands.
  11. Aquasana F-300R 300,000 Gallon Whole House Water Filtration System 20-Inch Sediment Pre-Filter Replacement: 11 단계, 이미지 1개 중 1개
    • Tighten the filter housing canister with the filter wrench.
  12. Aquasana F-300R 300,000 Gallon Whole House Water Filtration System 20-Inch Sediment Pre-Filter Replacement: 12 단계, 이미지 2개 중 1개 Aquasana F-300R 300,000 Gallon Whole House Water Filtration System 20-Inch Sediment Pre-Filter Replacement: 12 단계, 이미지 2개 중 2개
    • Turn on the water supply by turning the water valve(s) to be vertical, or parallel to the water pipe.
  13. Aquasana F-300R 300,000 Gallon Whole House Water Filtration System 20-Inch Sediment Pre-Filter Replacement: 13 단계, 이미지 1개 중 1개
    • Run water in a sink or tub for 1-2 minutes to flush out the system and remove any air in the pipes.
결론
Repeat steps every 2-3 months for best results.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Kathryn Hall
회원 가입일: 09/28/22
247 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 6
지난 30일: 19
전체 시간: 379
