주요 콘텐츠로 건너뛰기
Archos 101 G9 Flash Memory Replacement
필요한 것
  1. Archos 101 G9 Flash Memory Replacement, Display Assembly: 1 단계, 이미지 1개 중 1개
    • Place an iFixit opening tool in the crease where the display assembly and back of the device meet.
    • Slide the tool firmly through the crease on one side of the device, twisting as you go to create separation.
    • When you reach the corner, carefully pry the two halves of the device apart.
    • There are small clips along the edges that need to stay intact in order to properly reassemble the device. Be very gentle when prying so as not to break the clips.
    • Repeat for the remaining three sides and corners.
  2. Archos 101 G9 Flash Memory Replacement: 2 단계, 이미지 2개 중 1개 Archos 101 G9 Flash Memory Replacement: 2 단계, 이미지 2개 중 2개
    • Separate the halves of the device.
    • Ensure that you separate from the top and you keep the bottoms of both pieces near each other so as not to damage the ribbon cables that connect the halves.
  3. Archos 101 G9 Flash Memory Replacement: 3 단계, 이미지 2개 중 1개 Archos 101 G9 Flash Memory Replacement: 3 단계, 이미지 2개 중 2개
    • Gently remove both ribbon cables from their sockets on the motherboard.
  4. Archos 101 G9 Flash Memory Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the white and black coaxial cables with gold tips from the motherboard.
  5. Archos 101 G9 Flash Memory Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the display assembly from the back panel.
  6. Archos 101 G9 Flash Memory Replacement, Motherboard: 6 단계, 이미지 1개 중 1개
    • Remove the 2 mm screw that holds the motherboard in place using a Phillips #0 screwdriver.
  7. Archos 101 G9 Flash Memory Replacement: 7 단계, 이미지 1개 중 1개
    • Carefully remove the ribbon cable from its socket on the motherboard.
  8. Archos 101 G9 Flash Memory Replacement: 8 단계, 이미지 1개 중 1개
    • Remove the tape covering all of the solder connections on the motherboard.
  9. Archos 101 G9 Flash Memory Replacement: 9 단계, 이미지 1개 중 1개
    • Desolder all six of the connections that were underneath the tape.
  10. Archos 101 G9 Flash Memory Replacement: 10 단계, 이미지 1개 중 1개
    • Remove the motherboard from the tablet.
  11. Archos 101 G9 Flash Memory Replacement, Flash Memory: 11 단계, 이미지 1개 중 1개
    • Flip the motherboard around to the backside and pry off the silver covering using a nylon spudger.
  12. Archos 101 G9 Flash Memory Replacement: 12 단계, 이미지 1개 중 1개
    • Remove the largest black rectangle using the Hakko microsoldering kit.
결론
작성자
3다른 기여자 명과 함께
Deneille Davids
회원 가입일: 10/28/21
181 평판
안내서 2개를 작성함
UMass Dartmouth, Team 4-1, Gulbrandsen Fall 2021 UMass Dartmouth, Team 4-1, Gulbrandsen Fall 2021 회원
UMASSD-GULBRANDSEN-F21S4G1
3 회원들
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 12
전체 시간: 427
