소개
If the battery in your device won't hold a charge or is no longer working at all, this guide will help you to remove the old battery and replace it with a new one.
필요한 것
Pry open the tablet by having the tablet face upward. To pry open, start over in the left corner (by the buttons) working clockwise until the tablet is open.
Once the screen is separated from the back panel, you will see two cables connecting the screen to the interior of the tablet (one silver, one black)
Remove the black tape that is holding the end of the black cable to the white tab.
Gently pull the cable away from the tab with tweezers disconnecting the plug from the outlet.
다른 3명이 해당 안내서를 완성하였습니다.
