주요 콘텐츠로 건너뛰기
Archos 97 Carbon Battery Replacement
필요한 것
  1. Archos 97 Carbon Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Pry open the tablet by having the tablet face upward. To pry open, start over in the left corner (by the buttons) working clockwise until the tablet is open.
  2. Archos 97 Carbon Battery Replacement: 2 단계, 이미지 1/2 Archos 97 Carbon Battery Replacement: 2 단계, 이미지 2/2
    • Once the screen is separated from the back panel, you will see two cables connecting the screen to the interior of the tablet (one silver, one black)
    • Remove the black tape that is holding the end of the black cable to the white tab.
    • Gently pull the cable away from the tab with tweezers disconnecting the plug from the outlet.
  3. Archos 97 Carbon Battery Replacement: 3 단계, 이미지 1/1
    • Remove the silver cable by removing the tape that connects the cable and screen. Gently detach the gold cable from the outlet.
  4. Archos 97 Carbon Battery Replacement: 4 단계, 이미지 1/2 Archos 97 Carbon Battery Replacement: 4 단계, 이미지 2/2
    • Now the interior of the tablet is fully accessible.
    • Heat the soldering gun until it is fully heated. Place the tip of the soldering gun over the solder that seals the red and black battery cables to the motherboard. Once the solder is heated the cables can be removed.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Kirsti McCarty
회원 가입일: 03/03/15
110 평판
안내서 1개 작성함
Sam Houston State, Team 13-5, Blackburne Winter 2015 Sam Houston State, Team 13-5, Blackburne Winter 2015 회원
SHSU-BLACKBURNE-W15S13G5
3 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 8
30일 전: 15
전체 시간: 3,831
