주요 콘텐츠로 건너뛰기
Archos 97 Carbon Display Screen Replacement
필요한 것
  1. Archos 97 Carbon Display Screen Replacement, Removing the old cover from tablet: 1 단계, 이미지 1/2 Archos 97 Carbon Display Screen Replacement, Removing the old cover from tablet: 1 단계, 이미지 2/2
    • Lay your tablet upwards facing you.
    • Using the opening tool, begin by prying the tablet starting in the top left corner. This can be found near the volume and power buttons.
    • Begin to work your way around the tablet in a clockwise motion to separate the screen from the cover.
  2. Archos 97 Carbon Display Screen Replacement, Removing the white tab from tablet: 2 단계, 이미지 1/3 Archos 97 Carbon Display Screen Replacement, Removing the white tab from tablet: 2 단계, 이미지 2/3 Archos 97 Carbon Display Screen Replacement, Removing the white tab from tablet: 2 단계, 이미지 3/3
    • Once you have opened the screen, you will see two cables that connect the screen and the interior of the tablet.
    • Remove the white tab located on the right side of the interior by removing the tape and plug that connects it to the tab.
  3. Archos 97 Carbon Display Screen Replacement, Removing the black tape from the tablet: 3 단계, 이미지 1/2 Archos 97 Carbon Display Screen Replacement, Removing the black tape from the tablet: 3 단계, 이미지 2/2
    • On the left side of the tablet, you will see a silver cable connecting the screen to the motherboard.
    • Using the tweezers, remove the black tape that is connecting the cable and screen. This will allow the gold connector to come loose.
    • The screen should be separated from the tablet.
  4. Archos 97 Carbon Display Screen Replacement, Removing the screws: 4 단계, 이미지 1/2 Archos 97 Carbon Display Screen Replacement, Removing the screws: 4 단계, 이미지 2/2
    • Remove the screws on the backside of the screen using a screwdriver.
    • There are four screws; one is covered by tape.
  5. Archos 97 Carbon Display Screen Replacement, Removing screen from frame: 5 단계, 이미지 1/3 Archos 97 Carbon Display Screen Replacement, Removing screen from frame: 5 단계, 이미지 2/3 Archos 97 Carbon Display Screen Replacement, Removing screen from frame: 5 단계, 이미지 3/3
    • Gently pry the screen from the black frame that surrounds it using the opening tool.
    • Work in a clockwise motion until the screen is detached from the frame.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Allyson Seber
회원 가입일: 03/03/15
311 평판
안내서 2개 작성하였습니다
Sam Houston State, Team 13-5, Blackburne Winter 2015 Sam Houston State, Team 13-5, Blackburne Winter 2015 회원
SHSU-BLACKBURNE-W15S13G5
3 회원들
안내서 8개 작성하였습니다
댓글 한 개
Hi,
Is this similar to replacing the touch screen on the Archos 101B model?.
colin - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 9
전체 시간: 1,583
