주요 콘텐츠로 건너뛰기
Archos 97 Carbon motherboard Replacement
필요한 것
  1. Archos 97 Carbon motherboard Replacement, mother board: 1 단계, 이미지 1/1
    • With the tablet facing you pry open the tablet. Start over in the left corner (by the buttons) working clockwise until the tablet is open using either a set of opening picks or a plastic pry tool.
  2. Archos 97 Carbon motherboard Replacement: 2 단계, 이미지 1/2 Archos 97 Carbon motherboard Replacement: 2 단계, 이미지 2/2
    • Once the screen is separated from the back panel, there will be two cables connecting the screen to the interior of the tablet (one silver, one black).
    • Start with the black cable that is connected to the white tab. Remove the black tape that is holding the end of the cable to the tab.
    • Then gently pull the cable away from the tab with tweezers, disconnecting the plug from the outlet.
  3. Archos 97 Carbon motherboard Replacement: 3 단계, 이미지 1/1
    • Now remove the silver cable by removing the tape connecting the cable and screen, then gently detaching the gold cable from the outlet.
  4. Archos 97 Carbon motherboard Replacement: 4 단계, 이미지 1/3 Archos 97 Carbon motherboard Replacement: 4 단계, 이미지 2/3 Archos 97 Carbon motherboard Replacement: 4 단계, 이미지 3/3
    • Now the interior of the tablet is fully accessible.
    • Heat up the soldering iron and once fully heated put the tip of the soldering iron on the connection terminals on the motherboard. Once the solder melts the cables and be easily pulled away.
    • With soldering iron also disconnect the four speaker cables on the right side of the motherboard. Put the tip of the soldering iron on each connection, melting the solder so the wires can be removed.
  5. Archos 97 Carbon motherboard Replacement: 5 단계, 이미지 1/3 Archos 97 Carbon motherboard Replacement: 5 단계, 이미지 2/3 Archos 97 Carbon motherboard Replacement: 5 단계, 이미지 3/3
    • Using a Philips #00 screwdriver, unscrew the 3 screws that connects the motherboard to the tablet.
  6. Archos 97 Carbon motherboard Replacement: 6 단계, 이미지 1/3 Archos 97 Carbon motherboard Replacement: 6 단계, 이미지 2/3 Archos 97 Carbon motherboard Replacement: 6 단계, 이미지 3/3
    • When the motherboard is completely unscrewed, flip it over so you can see the underside.
    • Using tweezers, gently press the sides of the black plug and pull away until the cable is detached.
    • Remove the other cable connector by gently pressing on the sides of the plug and pulling away until it is detached as well.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Sam Nance
회원 가입일: 03/03/15
207 평판
안내서 1개 작성함
Sam Houston State, Team 13-5, Blackburne Winter 2015 Sam Houston State, Team 13-5, Blackburne Winter 2015 회원
SHSU-BLACKBURNE-W15S13G5
3 회원들
안내서 8개 작성하였습니다
댓글 한 개
Good morning
Do you know where i can buy an other mother board?
Because i can found any supplier to buy one.
thank in advance
Best Regard
Joël
Joel13 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 8
전체 시간: 1,114
