주요 콘텐츠로 건너뛰기
Armani Exchange AX1017 Lens Replacement
필요한 것
  1. Armani Exchange AX1017 Lens  Replacement, Glasses Lens: 1 단계, 이미지 1/2 Armani Exchange AX1017 Lens  Replacement, Glasses Lens: 1 단계, 이미지 2/2
    • Clean the outer frame of the glasses with a clean cloth.
  2. Armani Exchange AX1017 Lens  Replacement: 2 단계, 이미지 1/2 Armani Exchange AX1017 Lens  Replacement: 2 단계, 이미지 2/2
    • Remove the screw between the lens and the frame using the glasses repair kit's Phillips-head screwdriver.
  3. Armani Exchange AX1017 Lens  Replacement: 3 단계, 이미지 1/2 Armani Exchange AX1017 Lens  Replacement: 3 단계, 이미지 2/2
    • Carefully remove the damaged lens from the unscrewed frame.
  4. Armani Exchange AX1017 Lens  Replacement: 4 단계, 이미지 1/1
    • Once removed, take a damp cloth (a cloth soaked in rubbing alcohol is preferred for the best clean) and clean inside of frame.
  5. Armani Exchange AX1017 Lens  Replacement: 5 단계, 이미지 1/2 Armani Exchange AX1017 Lens  Replacement: 5 단계, 이미지 2/2
    • Take your new lens and place it carefully into the frame. Make sure that the lens is slotted correctly into the frame, aligning the edges on the lens and the frame.
  6. Armani Exchange AX1017 Lens  Replacement: 6 단계, 이미지 1/1
    • Screw the frame back together using the Phillips head screwdriver, ensuring that the new lens is slotted correctly into the frame.
결론
The guide gives complete instructions on removing, replacing, and returning the glasses back to their original state.
다른 한 분이 해당 안내서를 완성하였습니다.
Collin Barlow
회원 가입일: 09/17/20
154 평판
안내서 1개 작성함
University of Memphis, Team S3-G69, Willis Fall 2020 University of Memphis, Team S3-G69, Willis Fall 2020 회원
UM-WILLIS-F20S3G69
1 회원
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 12
30일 전: 73
전체 시간: 1,904
