주요 콘텐츠로 건너뛰기
ArmorAll AA255 Motor Replacement
필요한 것
  1. ArmorAll AA255 Motor Replacement, Lower Motor Housing: 1 단계, 이미지 1/1
    • Remove the orange main housing unit from the vacuum bucket by pulling outward on the handle tabs while lifting upward as shown.
  2. ArmorAll AA255 Motor Replacement: 2 단계, 이미지 1/1
    • Remove the five 15mm PH2 screws.
  3. ArmorAll AA255 Motor Replacement: 3 단계, 이미지 1/1
    • Remove the 15 mm T20 screw. This screw is located nearest the power cord.
  4. ArmorAll AA255 Motor Replacement: 4 단계, 이미지 1/2 ArmorAll AA255 Motor Replacement: 4 단계, 이미지 2/2
    • Gently separate the upper and lower sections of the main housing.
  5. ArmorAll AA255 Motor Replacement, Motor: 5 단계, 이미지 1/3 ArmorAll AA255 Motor Replacement, Motor: 5 단계, 이미지 2/3 ArmorAll AA255 Motor Replacement, Motor: 5 단계, 이미지 3/3
    • Use a PH2 screwdriver to remove the five 15mm screws on the ball cage under the main housing.
    • Pull the ball cage to remove it from the main housing.
  6. ArmorAll AA255 Motor Replacement: 6 단계, 이미지 1/3 ArmorAll AA255 Motor Replacement: 6 단계, 이미지 2/3 ArmorAll AA255 Motor Replacement: 6 단계, 이미지 3/3
    • Remove one 13mm nut from the main housing.
    • The metal ring under the nut has sharp edges. You may need to use a tool such as pliers to prevent injury.
    • Remove metal ring from the main housing.
    • Use a PH2 screwdriver to remove the four 12mm screws from the main housing.
  7. ArmorAll AA255 Motor Replacement: 7 단계, 이미지 1/3 ArmorAll AA255 Motor Replacement: 7 단계, 이미지 2/3 ArmorAll AA255 Motor Replacement: 7 단계, 이미지 3/3
    • Turn the whole body over to separate motor cover.
    • Use a PH2 screwdriver to remove the five 15mm screw.
    • Remove the white power wire from the motor cover.
    • Pull the motor cover from the main housing.
  8. ArmorAll AA255 Motor Replacement: 8 단계, 이미지 1/2 ArmorAll AA255 Motor Replacement: 8 단계, 이미지 2/2
    • Use a plastic opening tool to remove two cables from the motor. One white cable is from the power cord, and one black cable is from the switch.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
    • You may need to mark the color of the wire on each terminal for reassembly.
  9. ArmorAll AA255 Motor Replacement: 9 단계, 이미지 1/2 ArmorAll AA255 Motor Replacement: 9 단계, 이미지 2/2
    • The motor is ready for replacement. Pull the motor to separate.
결론
다른 6명이 해당 안내서를 완성하였습니다.
YeaJun Yoo
회원 가입일: 02/11/16
302 평판
안내서 1개 작성함
IUPUI, Team 2-1, Baechle Spring 2016 IUPUI, Team 2-1, Baechle Spring 2016 회원
IUPUI-BAECHLE-S16S2G1
4 회원들
안내서 4개 작성하였습니다
댓글 4개
What is the motor product no? It will help if there is a link to buy the motor
Austin K - 답글
Medida de los carboncitos que lleva el motor?
SERVANDO ARTEA FAVELA - 답글
Buenas nochew necesito saber si existe a la venta la hélice o ventiladora que hace la succión de la aspiradora. Porfavor alguien puede ayudarme dejo mi correo erikazavala2882@gmail.com desde Honduras.
erikazavala2882 - 답글
Part #for motor ???? Mine just the carbon brush is worn. Need replacement part # for motor or brushes ????
A Anderson - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 15
30일 전: 64
전체 시간: 3,966
