주요 콘텐츠로 건너뛰기
기기를 고치세요
수리할 권리
부품 & 도구
소개
This guide, along with the prerequisite guides, will demonstrate how to remove and replace the camera in your Arnova 7K G3 tablet.
  1. Remove four 5 mm Phillips #00 screws from each corner of the tablet. Remove four 5 mm Phillips #00 screws from each corner of the tablet. Remove four 5 mm Phillips #00 screws from each corner of the tablet.
    • Remove four 5 mm Phillips #00 screws from each corner of the tablet.
  2. Place the iFixit opening tool in the notches between the cases and pull the covers apart. Place the iFixit opening tool in the notches between the cases and pull the covers apart.
    • Place the iFixit opening tool in the notches between the cases and pull the covers apart.
  3. Repeat step two until 3/4 of the rear cover is unlatched.
    • Repeat step two until 3/4 of the rear cover is unlatched.
    • Proceed to remove the rear cover by gently pulling it apart by hand.
  4. Peel the copper tape covering the ribbon connector with a set of tweezers. Peel the copper tape covering the ribbon connector with a set of tweezers.
    • Peel the copper tape covering the ribbon connector with a set of tweezers.
  5. LCD iPhone 스크린 수리 키트
    평생 품질 보증이 적용되는 저렴한 옵션.
    키트 쇼핑하기
    수리의 질 말고 비용을 절감하세요.
    키트 쇼핑하기
  6. Locate the two gray pins on the ribbon connector. Grab the first pin with tweezers and gently pull it towards the ribbon. Repeat the step. Gently pull the ribbon cable out of the connection port.
    • Locate the two gray pins on the ribbon connector.
    • Grab the first pin with tweezers and gently pull it towards the ribbon. Repeat the step.
    • Gently pull the ribbon cable out of the connection port.
  7. Locate the ribbon connector two. Locate the pins of ribbon connector two. Repeat step two for unlocking the pins. Gently pull the ribbon out of the connection port.
    • Locate the ribbon connector two.
    • Locate the pins of ribbon connector two. Repeat step two for unlocking the pins.
    • Gently pull the ribbon out of the connection port.
  8. Remove the two Phillips #00 screws from the motherboard.
    • Remove the two Phillips #00 screws from the motherboard.
  9. Gently lift up the motherboard and reorient it in a more efficient manner in order to locate the desired components.
    • Gently lift up the motherboard and reorient it in a more efficient manner in order to locate the desired components.
  10. Locate the camera and camera ribbon connection on the backside of the motherboard. Locate the camera and camera ribbon connection on the backside of the motherboard.
    • Locate the camera and camera ribbon connection on the backside of the motherboard.
  11. Unlock the camera ribbon connector clip using a pair of tweezers. Unlock the camera ribbon connector clip using a pair of tweezers.
    • Unlock the camera ribbon connector clip using a pair of tweezers.
  12. Gently by hand, remove the camera and its ribbon by pulling the camera away from the motherboard. There is adhesive foam on the backside of the camera that may cause some difficulty when removing the camera. There is adhesive foam on the backside of the camera that may cause some difficulty when removing the camera.
    • Gently by hand, remove the camera and its ribbon by pulling the camera away from the motherboard.
    • There is adhesive foam on the backside of the camera that may cause some difficulty when removing the camera.
결론
Kue
회원 가입일: 2015년 03월 18일
301 평판
안내서 3개 작성하였습니다
Michigan Tech, Team 1-2, Lauer Spring 2015 Michigan Tech, Team 1-2, Lauer Spring 2015 회원
MTU-LAUER-S15S1G2
2 회원들
안내서 10개 작성하였습니다
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 147
