주요 콘텐츠로 건너뛰기
Arnova 7K G3 Rubber Feet Replacement
필요한 것
  1. Arnova 7K G3 Rubber Feet Replacement, Rear Cover: 1 단계, 이미지 1/3 Arnova 7K G3 Rubber Feet Replacement, Rear Cover: 1 단계, 이미지 2/3 Arnova 7K G3 Rubber Feet Replacement, Rear Cover: 1 단계, 이미지 3/3
    • Remove four 5 mm Phillips #00 screws from each corner of the tablet.
  2. Arnova 7K G3 Rubber Feet Replacement: 2 단계, 이미지 1/2 Arnova 7K G3 Rubber Feet Replacement: 2 단계, 이미지 2/2
    • Place the iFixit opening tool in the notches between the cases and pull the covers apart.
  3. Arnova 7K G3 Rubber Feet Replacement: 3 단계, 이미지 1/1
    • Repeat step two until 3/4 of the rear cover is unlatched.
    • Proceed to remove the rear cover by gently pulling it apart by hand.
  4. Arnova 7K G3 Rubber Feet Replacement, Rubber Feet: 4 단계, 이미지 1/2 Arnova 7K G3 Rubber Feet Replacement, Rubber Feet: 4 단계, 이미지 2/2
    • Locate the two lower bumpers on the back cover. These are the rubber feet.
    • Flip the cover over to reveal the inside.
    • Locate the two rubber tabs, there are two for each rubber foot. They are located on the inside of the cover.
  5. Arnova 7K G3 Rubber Feet Replacement: 5 단계, 이미지 1/1
    • Push the two tabs on each foot down using the pointed end of a spudger.
    • It may take some force to push in the tabs. Prying with the pointed end of the spudger and wiggling the tab free may be necessary.
  6. Arnova 7K G3 Rubber Feet Replacement: 6 단계, 이미지 1/1
    • Flip the cover back over so you see the outside. Remove the rubber feet if they have not already fallen out.
결론
To reassemble your device, follow these instructions in reverse order with the new rubber feet.
Tyler Sigafoose
회원 가입일: 03/19/15
210 평판
안내서 2개 작성하였습니다
Michigan Tech, Team 1-2, Lauer Spring 2015 Michigan Tech, Team 1-2, Lauer Spring 2015 회원
MTU-LAUER-S15S1G2
2 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 172
