주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Aroma ARC-1030SB F3 Error Fix
필요한 것
    • Unplug rice cooker from outlet.
  1. Aroma ARC-1030SB F3 Error Fix, Remove Condensation Collector: 2 단계, 이미지 1개 중 1개
    • Remove Condensation Collector to expose screw underneath.
  2. Aroma ARC-1030SB F3 Error Fix, Remove Screw: 3 단계, 이미지 1개 중 1개
    • Using a Philips screw driver, remove the now exposed screw.
  3. Aroma ARC-1030SB F3 Error Fix, Remove Condensation plate/holder: 4 단계, 이미지 3개 중 1개 Aroma ARC-1030SB F3 Error Fix, Remove Condensation plate/holder: 4 단계, 이미지 3개 중 2개 Aroma ARC-1030SB F3 Error Fix, Remove Condensation plate/holder: 4 단계, 이미지 3개 중 3개
    • Now that the screw is out, remove the piece that the screw was holding onto from Rice Cooker.
    • Now that this piece has been removed, you may notice that there are two wires going up into the lid (these wires connect to the Top Thermo sensor) and that one of them may be partially or completely severed. This is the likely cause of the F3 Error.
  4. Aroma ARC-1030SB F3 Error Fix, Separate lid from Rice Cooker: 5 단계, 이미지 3개 중 1개 Aroma ARC-1030SB F3 Error Fix, Separate lid from Rice Cooker: 5 단계, 이미지 3개 중 2개 Aroma ARC-1030SB F3 Error Fix, Separate lid from Rice Cooker: 5 단계, 이미지 3개 중 3개
    • Using the Prying tool or a Flat tool/object, pry open the Rice Cooker Lid by running the tool along the seams.
    • Once loosened, press the lid release/open button and lift the lid. It should easily pop right off.
  5. Aroma ARC-1030SB F3 Error Fix, Check area for Damage: 6 단계, 이미지 2개 중 1개 Aroma ARC-1030SB F3 Error Fix, Check area for Damage: 6 단계, 이미지 2개 중 2개
    • Assess the damage and cut off any bad/burnt ends of the severed wire(s). Best practice would be to snip away any exposed wire so that you have fresh new wire to work with.
  6. Aroma ARC-1030SB F3 Error Fix, Strip wires: 7 단계, 이미지 1개 중 1개
    • Strip both ends of the wire(s), I tend to just eyeball it and strip roughly 3-5 cm of the plastic off the wire.
  7. Aroma ARC-1030SB F3 Error Fix, Splice: 8 단계, 이미지 3개 중 1개 Aroma ARC-1030SB F3 Error Fix, Splice: 8 단계, 이미지 3개 중 2개 Aroma ARC-1030SB F3 Error Fix, Splice: 8 단계, 이미지 3개 중 3개
    • Once stripped, I like to spread the thin wires out and splice the wire(s) (push both ends of the wire into one another before twisting them together).
  8. Aroma ARC-1030SB F3 Error Fix, Wrap the exposed wires: 9 단계, 이미지 3개 중 1개 Aroma ARC-1030SB F3 Error Fix, Wrap the exposed wires: 9 단계, 이미지 3개 중 2개 Aroma ARC-1030SB F3 Error Fix, Wrap the exposed wires: 9 단계, 이미지 3개 중 3개
    • Cut a small piece of electrical tape and wrap it around the exposed wires.
  9. Aroma ARC-1030SB F3 Error Fix, Test and Done!: 10 단계, 이미지 2개 중 1개 Aroma ARC-1030SB F3 Error Fix, Test and Done!: 10 단계, 이미지 2개 중 2개
    • All done! I would recommend plugging the rice cooker in now and running it to confirm that the error code is gone for good before putting it back together in reverse order. This way you wont have to tear it apart again if you need to re-splice the wire(s).
결론
다른 6명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Lolue
회원 가입일: 01/23/24
397 평판
안내서 1개를 작성함
2가이드 댓글
Thank you. This was the exact issue and I just followed the given instructions and was able to fix. Its all working as expected now. Thanks again !!
Karan Reddy - 답글 공유
Thank you, Lolue.
This worked for me too. The Instructions are very clear and it was very easy to fix this.
Vinay Chimakurthy - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 33
지난 30일: 120
전체 시간: 3,151
