소개
This guide will show how to remove a broken arrow vane and replace it with a new one.
필요한 것
Gather all supplies needed to refletch the arrow.
Be sure the fletching jig is the correct jig for the amount of vanes on the arrow. The fletching jig in the following images is a three vane fletching jig.
Lay down one of your paper towels where you plan to work.
Use a pocket knife to scrape off the broken vane and glue.
Be sure to hold the blade away from you, at a 45 degree angle from the arrow.
Periodically check the arrow, by rubbing your finger on the surface of the arrow, to see if all the glue has been removed.
If all the glue has been removed the arrow will be smooth. If the glue hasn't been removed completely, your finger will feel small raises on the arrow.
Apply acetone to a paper towel and rub it on the area where the vane was removed.
Be sure the paper towel is sufficiently soaked with acetone. If the acetone isn't rubbed on enough, the grease from your finger will cause the new vane to fall off.
Be sure not to touch that part of the arrow you just cleaned for the rest of the process.
The supplies needed for this step are the following. The clamp, new vane, acetone, paper towel, q-tip, and fletching glue.
Be sure to have all supplies close at hand.
Glue dries fast, so you need to work at a quicker than normal pace. Don't work so fast that you mess up, but try to work swiftly when working with the fletching glue.
After the vane has finished drying; check to see if the vane is on correctly and straight. If so, the vane was properly replaced. If not, refer back to step 1 and start over.
If the vane is fixed, you may apply a small amount of acetone onto another q-tip and wipe off any excessive glue. Be sure not to wipe the new arrow vane.
To reassemble your device, you must finish the instructions.
다른 한 분이 해당 안내서를 완성하였습니다.
