주요 콘텐츠로 건너뛰기
Assembling Parabolic Solar Cooker Expansion Pipe and T-Bar
필요한 것
  1. Assembling Parabolic Solar Cooker Expansion Pipe and T-Bar, Assembling Parabolic Solar Cooker Tripod Base Stand: 1 단계, 이미지 1/2 Assembling Parabolic Solar Cooker Expansion Pipe and T-Bar, Assembling Parabolic Solar Cooker Tripod Base Stand: 1 단계, 이미지 2/2
    • Insert a 14mm bolt through each tripod leg and through the center plate. Secure each bolt by hand threading a nut on the other side.
    • Be sure the flat side of each tripod leg is facing toward the ground.
  2. Assembling Parabolic Solar Cooker Expansion Pipe and T-Bar: 2 단계, 이미지 1/1
    • Tighten each nut using two 14mm wrenches until each leg is stable and the tripod will stand on its own.
  3. Assembling Parabolic Solar Cooker Expansion Pipe and T-Bar, Assembling Parabolic Solar Cooker Expansion Pipe and T-Bar: 3 단계, 이미지 1/2 Assembling Parabolic Solar Cooker Expansion Pipe and T-Bar, Assembling Parabolic Solar Cooker Expansion Pipe and T-Bar: 3 단계, 이미지 2/2
    • Center the bottom of the expansion pipe between the tabs of the t-bar bracket. Insert a 14mm bolt through the bracket and expansion pipe and hand thread a nut. Use 14mm wrenches to secure the assembly.
    • It does not matter which direction the 14mm bolt is inserted from.
결론
To disassemble your device, follow these instructions in reverse order.
다른 2명이 해당 안내서를 완성하였습니다.
Ashlie Reott
회원 가입일: 10/20/13
340 평판
안내서 3개 작성하였습니다
Cal Poly, Team 4-30, Amido Fall 2013 Cal Poly, Team 4-30, Amido Fall 2013 회원
CPSU-AMIDO-F13S4G30
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 5
전체 시간: 526
