주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Assembling Parabolic Solar Cooker Tripod Base Stand
필요한 것
  1. Assembling Parabolic Solar Cooker Tripod Base Stand, Assembling Parabolic Solar Cooker Tripod Base Stand: 1 단계, 이미지 2개 중 1개 Assembling Parabolic Solar Cooker Tripod Base Stand, Assembling Parabolic Solar Cooker Tripod Base Stand: 1 단계, 이미지 2개 중 2개
    • Insert a 14mm bolt through each tripod leg and through the center plate. Secure each bolt by hand threading a nut on the other side.
    • Be sure the flat side of each tripod leg is facing toward the ground.
  2. Assembling Parabolic Solar Cooker Tripod Base Stand: 2 단계, 이미지 1개 중 1개
    • Tighten each nut using two 14mm wrenches until each leg is stable and the tripod will stand on its own.
결론
To disassemble your device, follow these instructions in reverse order.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Ashlie Reott
회원 가입일: 10/20/13
340 평판
안내서 3개를 작성함
Cal Poly, Team 4-30, Amido Fall 2013 Cal Poly, Team 4-30, Amido Fall 2013 회원
CPSU-AMIDO-F13S4G30
4 회원들
안내서 6개를 작성함
1가이드 댓글
Can I order the following part that was missing from the order that came in Aug 2025?
Please let me know, I can pay for these parts from you stock or spare parts.
36 x 10mm Nut/Bolt Pairs
6 Pipe Ring Brackets
12 x 14mm Nut/Bolt Pairs
2 Cooker Assembly Adjustment Star Knobs
Paul
my email is pn91006@yahoo.com
626-215-4038
Paul Ng
Paul Paul - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 43
전체 시간: 902
