주요 콘텐츠로 건너뛰기
Astak Mole Motor Replacement
필요한 것
  1. Astak Mole  Motor Replacement, Lower Case: 1 단계, 이미지 1개 중 1개
    • Remove the four bottom tabs in order to access the bottom screws.
  2. Astak Mole  Motor Replacement: 2 단계, 이미지 1개 중 1개
    • Remove all four 14 mm Phillips #1 screws.
  3. Astak Mole  Motor Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the SD card.
  4. Astak Mole  Motor Replacement: 4 단계, 이미지 1개 중 1개
    • Pry up the motherboard on the four points using a spudger.
    • The regular black nylon spudger should be used whenever possible, especially around sensitive internal components.
  5. Astak Mole  Motor Replacement: 5 단계, 이미지 1개 중 1개
    • Gently pull back the motherboard to expose many of the component's wired connections.
  6. Astak Mole  Motor Replacement, Electric Motor Assembly: 6 단계, 이미지 1개 중 1개
    • Unscrew both screws using the Phillips head (PH1) screw bit and set aside for reassembly
    • Screw Measurements: Length: 7.1mm
    • The motor should be free of its housing and only be attached to the motherboard by its wires.
  7. Astak Mole  Motor Replacement: 7 단계, 이미지 1개 중 1개
    • Sever motor connection to motherboard and remove wire carefully.
    • Optional: Use electrical adhesive to prevent dislodging of new wired connection.
결론
작성자
4다른 기여자 명과 함께
Andrew Birch
회원 가입일: 09/15/16
204 평판
안내서 2개를 작성함
USF Tampa, Team 2-2, Blackwell Fall 2016 USF Tampa, Team 2-2, Blackwell Fall 2016 회원
USFT-BLACKWELL-F16S2G2
4 회원들
안내서 12개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 14
전체 시간: 534
