소개
In this guide, we will be reaching and removing the motherboard from its housing in the Astro A40 Gen2. The motherboard is the only component inside the mixamp.
WARNING: Use caution when placing screws to the side as they are very small and easy to lose. Place them in groups apart from each other to avoid confusion.
필요한 것
Remove the dials using either a metal spudger or your hands. Be careful as the dials may be difficult to remove.
Remove the one 4.5 mm Phillips #0 screw on the back panel of the mixamp.
Using a large metal spudger, detach all plastic clips holding the bottom and top casings together.
Remove the input casing using your fingers.
Remove the four 5.8 mm Phillips #0 screws on the motherboard.
다른 2명이 해당 안내서를 완성하였습니다.
댓글 한 개
Where would I find a motherboard? And would it save money fixing the mixamp?
