주요 콘텐츠로 건너뛰기
Astro A40 Gen2 Speaker Replacement
필요한 것
  1. Astro A40 Gen2 Speaker Replacement, Ear Pad: 1 단계, 이미지 1/2 Astro A40 Gen2 Speaker Replacement, Ear Pad: 1 단계, 이미지 2/2
    • Pull one corner of the pad to release it from the headset.
    • Pull the rest of the ear pad off.
  2. Astro A40 Gen2 Speaker Replacement, Speaker: 2 단계, 이미지 1/2 Astro A40 Gen2 Speaker Replacement, Speaker: 2 단계, 이미지 2/2
    • Locate the four 4.5 mm Philips #0 screws on the panel shown.
    • Remove them using a Phillips #0 head screwdriver.
    • Remove the panel.
  3. Astro A40 Gen2 Speaker Replacement: 3 단계, 이미지 1/2 Astro A40 Gen2 Speaker Replacement: 3 단계, 이미지 2/2
    • Using either your fingers or a plastic opening tool, pry off the speaker cover.
  4. Astro A40 Gen2 Speaker Replacement: 4 단계, 이미지 1/1
    • Locate the four 4.5 mm Philips #0 screws as shown on the speaker housing.
    • Remove the four screws using a Phillips #0 head screwdriver.
  5. Astro A40 Gen2 Speaker Replacement: 5 단계, 이미지 1/1
    • Remove the housing to reveal the speaker.
    • Make sure not to break the small wire holding the two portions together.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Donavan Feliz
회원 가입일: 01/22/15
444 평판
안내서 2개 작성하였습니다
Cal Poly, Team 20-18, Maness Winter 2015 Cal Poly, Team 20-18, Maness Winter 2015 회원
CPSU-MANESS-W15S20G18
4 회원들
안내서 10개 작성하였습니다
댓글 2개
Where do you buy the replacement speaker ? Thanks.
Steve Rosam - 답글
what speakers can these be replaced with? this guide is a little short on details about the actual removal and replacement of the speakers. the information here is just the start
Jasper W (Spike229) - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 23
전체 시간: 4,511
