주요 콘텐츠로 건너뛰기
Astro A40 TR External Headband Replacement
필요한 것
  1. Astro A40 TR External Headband Replacement, External Headband: 1 단계, 이미지 1/2 Astro A40 TR External Headband Replacement, External Headband: 1 단계, 이미지 2/2
    • Remove two hex screws on each side to free and remove the base plate. Do each step for both sides.
  2. Astro A40 TR External Headband Replacement: 2 단계, 이미지 1/2 Astro A40 TR External Headband Replacement: 2 단계, 이미지 2/2
    • Pull apart earpiece assembly and the connecting headband piece.
  3. Astro A40 TR External Headband Replacement: 3 단계, 이미지 1/2 Astro A40 TR External Headband Replacement: 3 단계, 이미지 2/2
    • Gently pull the padding layer off of both ends using your hands.
  4. Astro A40 TR External Headband Replacement: 4 단계, 이미지 1/3 Astro A40 TR External Headband Replacement: 4 단계, 이미지 2/3 Astro A40 TR External Headband Replacement: 4 단계, 이미지 3/3
    • Locate the black wiring and gently pull it out of the plastic headpiece component.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Mike
회원 가입일: 10/20/16
448 평판
안내서 3개 작성하였습니다
UMass Dartmouth, Team 6-5, Martin Fall 2016 UMass Dartmouth, Team 6-5, Martin Fall 2016 회원
UMASSD-MARTIN-F16S6G5
3 회원들
안내서 10개 작성하였습니다
댓글 6개
Is there any place you can purchase a new external headband? The part that holds the foam piece in place broke on mine yesterday :(
zironyy - 답글
i dont have the screws i lost them when i dropped my headset
Sniping_Ninja10 - 답글
Did you buy screws? I need as well but I don’t know which one is good!
photo -
Where Can I buy screws for? I know the size is T8 but how long? which one is good for? Please help me
photo - 답글
where can i buy a new headband
Dewis Polonia - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 13
30일 전: 68
전체 시간: 13,766
