주요 콘텐츠로 건너뛰기
Astro A40 TR Plus Mixamp M80 Wires in speaker Replacement
필요한 것
  1. Astro A40 TR Plus Mixamp M80 Wires in speaker Replacement, Ear Cushions: 1 단계, 이미지 2개 중 1개 Astro A40 TR Plus Mixamp M80 Wires in speaker Replacement, Ear Cushions: 1 단계, 이미지 2개 중 2개
    • Use your hand to firmly grasp the cushion and remove it from the speaker.
    • Repeat the process for the other side if needed.
    • The best place to grip it is where there is a tab sticking out. The tab will make it easier to remove.
    • When reassembling, note the curvature of the cushion to determine whether it's the left or the right cushion.
  2. Astro A40 TR Plus Mixamp M80 Wires in speaker Replacement, Motherboard: 2 단계, 이미지 3개 중 1개 Astro A40 TR Plus Mixamp M80 Wires in speaker Replacement, Motherboard: 2 단계, 이미지 3개 중 2개 Astro A40 TR Plus Mixamp M80 Wires in speaker Replacement, Motherboard: 2 단계, 이미지 3개 중 3개
    • Slide the plastic spudger beneath the dust cover of the speaker.
    • Lift the dust cover up with the plastic spudger.
    • Using your fingers, completely remove the dust cover from the speaker.
  3. Astro A40 TR Plus Mixamp M80 Wires in speaker Replacement: 3 단계, 이미지 3개 중 1개 Astro A40 TR Plus Mixamp M80 Wires in speaker Replacement: 3 단계, 이미지 3개 중 2개 Astro A40 TR Plus Mixamp M80 Wires in speaker Replacement: 3 단계, 이미지 3개 중 3개
    • Remove four 5 mm screws from the speaker protector using a JIS #1 screwdriver.
    • Use your hands to remove the speaker protector.
  4. Astro A40 TR Plus Mixamp M80 Wires in speaker Replacement: 4 단계, 이미지 2개 중 1개 Astro A40 TR Plus Mixamp M80 Wires in speaker Replacement: 4 단계, 이미지 2개 중 2개
    • Remove the two 2 mm long screws securing the motherboard using a Phillips #000 screwdriver.
  5. Astro A40 TR Plus Mixamp M80 Wires in speaker Replacement: 5 단계, 이미지 2개 중 1개 Astro A40 TR Plus Mixamp M80 Wires in speaker Replacement: 5 단계, 이미지 2개 중 2개
    • Use your fingers to hold the wire located by the covered part and gently lift it out of its cradle.
    • Carefully use your fingers to disconnect the colored wires connected to the motherboard.
    • If replacing the wires, ensure you carefully disconnect the remaining colored wires to replace them with new standard wires.
  6. Astro A40 TR Plus Mixamp M80 Wires in speaker Replacement, Wires in speaker: 6 단계, 이미지 3개 중 1개 Astro A40 TR Plus Mixamp M80 Wires in speaker Replacement, Wires in speaker: 6 단계, 이미지 3개 중 2개 Astro A40 TR Plus Mixamp M80 Wires in speaker Replacement, Wires in speaker: 6 단계, 이미지 3개 중 3개
    • Use your fingers to remove the black wire from your headphones.
결론
작성자
3다른 기여자 명과 함께
Yang Li
회원 가입일: 06/28/17
541 평판
안내서 5개를 작성함
댓글 한 개
But where do I buy the replacement speaker
David Landeros - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 11
전체 시간: 1,803
