주요 콘텐츠로 건너뛰기
Astro A50 2016 Headset Buttons Replacement
필요한 것
  1. Astro A50 2016 Headset Buttons Replacement, Headset Speakers: 1 단계, 이미지 2개 중 1개 Astro A50 2016 Headset Buttons Replacement, Headset Speakers: 1 단계, 이미지 2개 중 2개
    • Remove the magnetic ear pads by gently pulling them away from the headset. Be careful not to remove the left earpad, which houses the microphone, and ensure you're only removing the right earpad.
  2. Astro A50 2016 Headset Buttons Replacement: 2 단계, 이미지 1개 중 1개
    • Squeeze the plastic opening tool between the black plastic and foam pad on non mic side and then pry upwards to remove the felt pads covering the speaker.
  3. Astro A50 2016 Headset Buttons Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the four 6mm Phillips 1 screws.
  4. Astro A50 2016 Headset Buttons Replacement: 4 단계, 이미지 1개 중 1개
    • Lift the speaker module up off the device.
  5. Astro A50 2016 Headset Buttons Replacement, Headset Buttons: 5 단계, 이미지 1개 중 1개
    • Remove the three 6mm PH1 screws.
  6. Astro A50 2016 Headset Buttons Replacement: 6 단계, 이미지 1개 중 1개
    • Remove the four 6 mm PH1 screws.
  7. Astro A50 2016 Headset Buttons Replacement: 7 단계, 이미지 1개 중 1개
    • Dettach the thin circuit board from the ribbon with your hand by pulling the board and wire in different directions.
  8. Astro A50 2016 Headset Buttons Replacement: 8 단계, 이미지 1개 중 1개
    • Pull the two unscrewed buttons away from the ear cuffs with your hand.
  9. Astro A50 2016 Headset Buttons Replacement: 9 단계, 이미지 1개 중 1개
    • Remove the two 6mm PH1 screws.
    • Pull the unscrewed button away from the ear cuffs with your hand.
  10. Astro A50 2016 Headset Buttons Replacement: 10 단계, 이미지 2개 중 1개 Astro A50 2016 Headset Buttons Replacement: 10 단계, 이미지 2개 중 2개
    • Use your hands to pull the volume wheel up and away from the device.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Vincent Seguin
회원 가입일: 10/02/17
382 평판
안내서 3개를 작성함
Cal Poly, Team S15-G1, Livingston Fall 2017 Cal Poly, Team S15-G1, Livingston Fall 2017 회원
CPSU-LIVINGSTON-F17S15G1
3 회원들
안내서 13개를 작성함
2가이드 댓글
hola una pregunta saben donde consiguen la rueda de volumen ya que mis astro a50 de tercera generacion de xbox tiene un problema cuando le giras la rueda para subir el volumen y bajar el volumen ya que no funciona del todo bien, en pocas palabras no hace bien su funcion al regular el sonido al girar la rueda y quisiera reparar eso.
bryan200131 - 답글
Yo también tengo el mismo problema. He encontrado unas piezas similares en Ali express pero no sé si le queden a los astro a50. Son de la marca Logitech pero para los G933. La pieza se ve muy parecida. Para evitar problemas yo estoy buscando la placa de circuitos completa, pero no la he encontrado. Si sabes algo te agradecería lo compartieras
omar ramirez marin -
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 26
전체 시간: 2,703
