주요 콘텐츠로 건너뛰기
Astro A50 2016 Headset Speakers Replacement
필요한 것
  1. Astro A50 2016 Headset Speakers Replacement, Headset Speakers: 1 단계, 이미지 2개 중 1개 Astro A50 2016 Headset Speakers Replacement, Headset Speakers: 1 단계, 이미지 2개 중 2개
    • Remove the magnetic ear pads by gently pulling them away from the headset. Be careful not to remove the left earpad, which houses the microphone, and ensure you're only removing the right earpad.
  2. Astro A50 2016 Headset Speakers Replacement: 2 단계, 이미지 1개 중 1개
    • Squeeze the plastic opening tool between the black plastic and foam pad on non mic side and then pry upwards to remove the felt pads covering the speaker.
  3. Astro A50 2016 Headset Speakers Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the four 6mm Phillips 1 screws.
  4. Astro A50 2016 Headset Speakers Replacement: 4 단계, 이미지 1개 중 1개
    • Lift the speaker module up off the device.
결론
다른 6명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Vincent Seguin
회원 가입일: 10/02/17
382 평판
안내서 3개를 작성함
Cal Poly, Team S15-G1, Livingston Fall 2017 Cal Poly, Team S15-G1, Livingston Fall 2017 회원
CPSU-LIVINGSTON-F17S15G1
3 회원들
안내서 13개를 작성함
5가이드 댓글
Great, pictures and explaining. But where do i get an speaker to replace the old one?
D3EW D - 답글
I am also looking for the replacement speakers. They seem impossible to find
Steven Fleck -
hola me encantaria que me pudieran decir donde comprar el repuesto de uno de los altavocez, porque no encuentro nada
ruben el gay - 답글
Awesome, but I don’t believe see anywhere on how to fix the mic as it rotates 360 free spinning rather than locking in the 90° talk and mute positions…?
Tippio - 답글
this is almost no solution, your cover is broken, there is stop on plastic cover.
X Pi Acoustic(CN) -
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 12
지난 30일: 45
전체 시간: 7,470
