주요 콘텐츠로 건너뛰기
Astro A50 Astro A50 Speakers Replacement
필요한 것
  1. Astro A50 Astro A50 Speakers Replacement, Speakers: 1 단계, 이미지 1/1
    • Carefully remove the ear pad from the speaker that the microphone is attached to. Repeat on the other side.
  2. Astro A50 Astro A50 Speakers Replacement: 2 단계, 이미지 1/1
    • Remove the four screws from each side of the headset.
  3. Astro A50 Astro A50 Speakers Replacement: 3 단계, 이미지 1/1
    • After the screws are removed the black piece of the cover can now come off. Remove this piece.
  4. Astro A50 Astro A50 Speakers Replacement: 4 단계, 이미지 1/2 Astro A50 Astro A50 Speakers Replacement: 4 단계, 이미지 2/2
    • Then you will see more screws around the now silver edge and a black cushioning pad in the middle. The number of screws depends on the speaker you are replacing, one side has 2 screws while the other has 4.
  5. Astro A50 Astro A50 Speakers Replacement: 5 단계, 이미지 1/1
    • Remove the screws in the silver edge.
  6. Astro A50 Astro A50 Speakers Replacement: 6 단계, 이미지 1/1
    • Once the screws are removed, the speaker should come out now.
    • Note: the speaker might still be connected to the headset through a wire so you must be gentle pulling about the headset.
  7. Astro A50 Astro A50 Speakers Replacement: 7 단계, 이미지 1/1
    • After that take off the cover. If the speaker is still connected and no wires are visibly damaged, then the speaker(s) is not the problem with your device. Please refer back to the troubleshooting page and make sure that the Astro A50 has the newest firmware, etc. If the wire is not connected continue to the next step.
  8. Astro A50 Astro A50 Speakers Replacement: 8 단계, 이미지 1/2 Astro A50 Astro A50 Speakers Replacement: 8 단계, 이미지 2/2
    • To reconnect the wire you will need to solder the wire back to the mic port. If you need help soldering refer to the soldering guide here.
    • Note: soldering is very dangerous and should not be done without supervision if you have never done it before.
    • After that put the headset back together, check to verify that the speaker is working.
  9. Astro A50 Astro A50 Speakers Replacement: 10 단계, 이미지 1/1
    • If there is still no sound or static, then the speaker might be “blown” and/or needs to be replaced completely. If so, please order a new speaker and follow the same steps to replace the whole speaker.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Ramzi Bechara
회원 가입일: 10/28/15
155 평판
안내서 1개 작성함
UMass Dartmouth, Team 2-5, Shastany Fall 2015 UMass Dartmouth, Team 2-5, Shastany Fall 2015 회원
UMASSD-SHASTANY-F15S2G5
4 회원들
안내서 10개 작성하였습니다
댓글 4개
Great info and well explained. would you know where I could purchase a speaker?
nvandyk7 - 답글
I I have problem with my astro a50 ps4 I hear good but when I want talk to someone no one hears me please I want to solve, note the headset did not fall or be damaged!! Help me please
Omar - 답글
i blew out the left side of my earphone astro a50 for xbox one/pc and i wish i could order the parts but astro said they dont have a repair shop or parts. and that they will sell me a new one for a discounted price. that sucks
chris needham - 답글
Hi I need the part that holds the bar to head band part as mine has snapped
ERAGAMING97 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 28
전체 시간: 10,047
