소개
A very common problem with the speaker is that the headset and the transmitter de-sync. To solve this, refer to the Astro A50 user manual and re-sync your transmitter and the headset. If it's still not working , the soldering on the mic port might have come off and you will need to re-solder the wire to the speaker. To do this follow these steps:
필요한 것
Carefully remove the ear pad from the speaker that the microphone is attached to. Repeat on the other side.
After that take off the cover. If the speaker is still connected and no wires are visibly damaged, then the speaker(s) is not the problem with your device. Please refer back to the troubleshooting page and make sure that the Astro A50 has the newest firmware, etc. If the wire is not connected continue to the next step.
다른 3명이 해당 안내서를 완성하였습니다.
댓글 4개
i blew out the left side of my earphone astro a50 for xbox one/pc and i wish i could order the parts but astro said they dont have a repair shop or parts. and that they will sell me a new one for a discounted price. that sucks
Hi I need the part that holds the bar to head band part as mine has snapped
