주요 콘텐츠로 건너뛰기
Astro C40 TR Joystick Replacement
필요한 것
  1. Astro C40 TR Joystick Replacement, Joystick: 1 단계, 이미지 1/1
    • Unplug your controller from the video game console.
    • Turn the wireless mode off if it is activated on your controller.
  2. Astro C40 TR Joystick Replacement: 2 단계, 이미지 1/3 Astro C40 TR Joystick Replacement: 2 단계, 이미지 2/3 Astro C40 TR Joystick Replacement: 2 단계, 이미지 3/3
    • Use an H.20 Hexagonal screwdriver to loosen the two screws on each joystick's side.
    • Remove the face cover of the joystick by flipping the controller on its side.
    • Don't panic if the joystick falls off! It can be placed back on.
  3. Astro C40 TR Joystick Replacement: 3 단계, 이미지 1/3 Astro C40 TR Joystick Replacement: 3 단계, 이미지 2/3 Astro C40 TR Joystick Replacement: 3 단계, 이미지 3/3
    • Use the 30mm TORX Screwdriver to remove the screws from the module.
    • Push on the top frame until it pops off of the module.
    • If you have a whole new joystick module, you can skip to step 6.
  4. Astro C40 TR Joystick Replacement: 4 단계, 이미지 1/3 Astro C40 TR Joystick Replacement: 4 단계, 이미지 2/3 Astro C40 TR Joystick Replacement: 4 단계, 이미지 3/3
    • Connect the base frame replacement to the joystick module.
    • Insert the top frame on the module until it clicks back together.
  5. Astro C40 TR Joystick Replacement: 5 단계, 이미지 1/3 Astro C40 TR Joystick Replacement: 5 단계, 이미지 2/3 Astro C40 TR Joystick Replacement: 5 단계, 이미지 3/3
    • Reassemble the joystick module and plug it back into the controller.
    • Make sure the replacement and base frame are tightly screwed together.
    • Align the module and controller as you put joystick back together.
  6. Astro C40 TR Joystick Replacement: 6 단계, 이미지 1/2 Astro C40 TR Joystick Replacement: 6 단계, 이미지 2/2
    • Reassemble the controller by placing the face cover back on.
    • Tighten the screws on the face cover with the H.20 Hexagonal Screwdriver.
    • If it's difficult to tighten the screws, don't force it. The joystick and controller are probably not aligned correctly!
  7. Astro C40 TR Joystick Replacement: 7 단계, 이미지 1/1
    • Recalibrate the controller so the new joystick can be detected by the console.
    • Connect the controller to the console and activate wire-connect mode by clicking the controller's top right corner.
    • Push the button on the back of the controller. Hold it until the controller vibrates. Release the button and repeat.
결론
Pan
회원 가입일: 09/13/21
145 평판
안내서 1개 작성함
York University, Team E-21, Melo-Thaiss Fall 2021 York University, Team E-21, Melo-Thaiss Fall 2021 회원
YORK-MELO-THAISS-F21SEG21
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 38
30일 전: 179
전체 시간: 3,039
