주요 콘텐츠로 건너뛰기
Astrolux BL03 Disassembly
필요한 것
  1. Astrolux BL03 Disassembly, Astrolux BL03 Disassembly: 1 단계, 이미지 3개 중 1개 Astrolux BL03 Disassembly, Astrolux BL03 Disassembly: 1 단계, 이미지 3개 중 2개 Astrolux BL03 Disassembly, Astrolux BL03 Disassembly: 1 단계, 이미지 3개 중 3개
    • Both front cover (LEDs) and back cover (charging) can be pulled from the frame. Start with the back cover. You need to pry on the casing to let it go. Do not remove the front cover yet.
    • After removing back cover, you have access to the charging port. You can pull it and it comes right off
    • After that, you have access to the batteries which can be pulled. If you pull the batteries before disconnecting LEDs, you will break the cable
    • If you decide to remove the battery, you should pull leds first and unsolder batteries from it. Both removing the battery and leds is very difficult and is not recommended
결론
작성자
1다른 기여자 명과 함께
Marek D
회원 가입일: 07/19/23
73 평판
안내서 1개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 9
전체 시간: 92
