주요 콘텐츠로 건너뛰기
Asus 1015E-DS03 Front Screen Trim Replacement
필요한 것
  1. Asus 1015E-DS03 Front Screen Trim Replacement, Battery: 1 단계, 이미지 1/1
    • Hold the laptop using both hands with the battery facing upwards.
  2. Asus 1015E-DS03 Front Screen Trim Replacement: 2 단계, 이미지 1/1
    • Push the two tabs located below the battery in towards each other using your thumbs.
  3. Asus 1015E-DS03 Front Screen Trim Replacement: 3 단계, 이미지 1/1
    • Push the battery upwards and out of the laptop as shown.
  4. Asus 1015E-DS03 Front Screen Trim Replacement: 4 단계, 이미지 1/1
    • Continue to push the battery upwards until it is completely separated from the laptop as shown.
  5. Asus 1015E-DS03 Front Screen Trim Replacement, Front Screen Case: 5 단계, 이미지 1/1
    • Push up on the back of the tabs that cover the hinges connecting the screen to the base of the laptop.
    • While pushing up on the back of the tabs, insert the spudger into the opening created from pushing on the tabs until the tab detaches.
  6. Asus 1015E-DS03 Front Screen Trim Replacement: 6 단계, 이미지 1/2 Asus 1015E-DS03 Front Screen Trim Replacement: 6 단계, 이미지 2/2
    • Once the case has been separated from the laptop, pull the case off completely, using the plastic opening tool or your fingers.
    • You will hear popping noises which are to be expected.
  7. Asus 1015E-DS03 Front Screen Trim Replacement: 7 단계, 이미지 1/1
    • When the screen case has been successfully removed, the laptop should resemble the photo shown here.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Becca Day
회원 가입일: 03/23/16
297 평판
안내서 2개 작성하였습니다
Clemson, Team 7-4, Benson Spring 2016 Clemson, Team 7-4, Benson Spring 2016 회원
CLEM-BENSON-S16S7G4
5 회원들
안내서 7개 작성하였습니다
0 Comments
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 3
전체 시간: 423
