소개
Replacing a hard drive may be necessary if you are experiencing frequent crashes, data loss or file corruption. You also can upgrade the hard drive to store more data. Either way, just follow this simple guide!
필요한 것
Once the battery is removed, unscrew the highlighted 3mm screws (4) using a #0 Phillps head screwdriver.
Once the keyboard is removed, the base plate will be exposed
Remove the 3mm screws (11) using a #0 Phillips head screwdriver
다른 3명이 해당 안내서를 완성하였습니다.
