주요 콘텐츠로 건너뛰기
Asus 1015E-DS03 Hard Drive Replacement
필요한 것
  1. Asus 1015E-DS03 Hard Drive Replacement, Battery: 1 단계, 이미지 1/1
    • Hold the laptop using both hands with the battery facing upwards.
  2. Asus 1015E-DS03 Hard Drive Replacement: 2 단계, 이미지 1/1
    • Push the two tabs located below the battery in towards each other using your thumbs.
  3. Asus 1015E-DS03 Hard Drive Replacement: 3 단계, 이미지 1/1
    • Push the battery upwards and out of the laptop as shown.
  4. Asus 1015E-DS03 Hard Drive Replacement: 4 단계, 이미지 1/1
    • Continue to push the battery upwards until it is completely separated from the laptop as shown.
  5. Asus 1015E-DS03 Hard Drive Replacement, Keyboard: 5 단계, 이미지 1/1
    • Once the battery is removed, unscrew the highlighted 3mm screws (4) using a #0 Phillps head screwdriver.
    • Be very careful not to lose the screws, these four screws are very small.
  6. Asus 1015E-DS03 Hard Drive Replacement: 6 단계, 이미지 1/2 Asus 1015E-DS03 Hard Drive Replacement: 6 단계, 이미지 2/2
    • After all four screws are removed, flip the laptop over with the keyboard facing up.
    • Use a spudger to pry up where the keyboard is attached to the laptop on all sides until it is detached from the laptop.
    • It is normal to hear cracking noises when prying off the keyboard.
    • After keyboard is detached from laptop, there is a ribbon cable still attached to the motherboard. See next step before completely removing keyboard.
  7. Asus 1015E-DS03 Hard Drive Replacement: 7 단계, 이미지 1/1
    • After the keyboard is detached, the ribbon cable which connects the keyboard to the laptop's motherboard is exposed.
    • Be careful not to tear or rip the ribbon cable.
  8. Asus 1015E-DS03 Hard Drive Replacement: 8 단계, 이미지 1/1
    • Using the spudger push the white clips upwards that are holding the cable.
  9. Asus 1015E-DS03 Hard Drive Replacement: 9 단계, 이미지 1/2 Asus 1015E-DS03 Hard Drive Replacement: 9 단계, 이미지 2/2
    • Gently pull the strip out of the square slot.
  10. Asus 1015E-DS03 Hard Drive Replacement, Hard Drive: 10 단계, 이미지 1/2 Asus 1015E-DS03 Hard Drive Replacement, Hard Drive: 10 단계, 이미지 2/2
    • Once the keyboard is removed, the base plate will be exposed
    • Please note that 1 screw will be covered by the warranty sticker (not shown). To complete this step it is necessary to break the warranty sticker which voids the laptop warranty.
    • Remove the 3mm screws (11) using a #0 Phillips head screwdriver
  11. Asus 1015E-DS03 Hard Drive Replacement: 11 단계, 이미지 1/2 Asus 1015E-DS03 Hard Drive Replacement: 11 단계, 이미지 2/2
    • Use the spudger to 'pop' open the track-pad base, starting from the corner shown
    • Once the corner is popped it may be easier to use your fingers to pop off the entire track-pad base
    • You will hear popping. Although this is normal, use caution pulling the track-pad base from the rest of the laptop
  12. Asus 1015E-DS03 Hard Drive Replacement: 12 단계, 이미지 1/2 Asus 1015E-DS03 Hard Drive Replacement: 12 단계, 이미지 2/2
    • You can now lift both sections of the base, exposing the hard drive.
  13. Asus 1015E-DS03 Hard Drive Replacement: 13 단계, 이미지 1/3 Asus 1015E-DS03 Hard Drive Replacement: 13 단계, 이미지 2/3 Asus 1015E-DS03 Hard Drive Replacement: 13 단계, 이미지 3/3
    • Release the two ZIF connectors that are labeled "IO"
    • The white bar flips away from the ribbon cable, then the ribbon cable can be gently pulled and removed from the connector
  14. Asus 1015E-DS03 Hard Drive Replacement: 14 단계, 이미지 1/2 Asus 1015E-DS03 Hard Drive Replacement: 14 단계, 이미지 2/2
    • Gently remove the hard drive from the laptop by pulling it towards the right.
결론
다른 3명이 해당 안내서를 완성하였습니다.
TJ Hanley
회원 가입일: 03/21/16
203 평판
안내서 1개 작성함
Clemson, Team 7-4, Benson Spring 2016 Clemson, Team 7-4, Benson Spring 2016 회원
CLEM-BENSON-S16S7G4
5 회원들
안내서 7개 작성하였습니다
One Comment
I pulled out the hard drive from a working 1015PE. I have all the parts and most of the screws.
I am not going to put it back together.
Can anyone use the what is left?
B&R Computer Services.
Contact info at noappleis2old4us.com
January 26, 2023
Ron Re - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 12
전체 시간: 1,923
