주요 콘텐츠로 건너뛰기
Asus 1015E-DS03 Keyboard Replacement
필요한 것
  1. Asus 1015E-DS03 Keyboard Replacement, Battery: 1 단계, 이미지 1/1
    • Hold the laptop using both hands with the battery facing upwards.
  2. Asus 1015E-DS03 Keyboard Replacement: 2 단계, 이미지 1/1
    • Push the two tabs located below the battery in towards each other using your thumbs.
  3. Asus 1015E-DS03 Keyboard Replacement: 3 단계, 이미지 1/1
    • Push the battery upwards and out of the laptop as shown.
  4. Asus 1015E-DS03 Keyboard Replacement: 4 단계, 이미지 1/1
    • Continue to push the battery upwards until it is completely separated from the laptop as shown.
  5. Asus 1015E-DS03 Keyboard Replacement, Keyboard: 5 단계, 이미지 1/1
    • Once the battery is removed, unscrew the highlighted 3mm screws (4) using a #0 Phillps head screwdriver.
    • Be very careful not to lose the screws, these four screws are very small.
  6. Asus 1015E-DS03 Keyboard Replacement: 6 단계, 이미지 1/2 Asus 1015E-DS03 Keyboard Replacement: 6 단계, 이미지 2/2
    • After all four screws are removed, flip the laptop over with the keyboard facing up.
    • Use a spudger to pry up where the keyboard is attached to the laptop on all sides until it is detached from the laptop.
    • It is normal to hear cracking noises when prying off the keyboard.
    • After keyboard is detached from laptop, there is a ribbon cable still attached to the motherboard. See next step before completely removing keyboard.
  7. Asus 1015E-DS03 Keyboard Replacement: 7 단계, 이미지 1/1
    • After the keyboard is detached, the ribbon cable which connects the keyboard to the laptop's motherboard is exposed.
    • Be careful not to tear or rip the ribbon cable.
  8. Asus 1015E-DS03 Keyboard Replacement: 8 단계, 이미지 1/1
    • Using the spudger push the white clips upwards that are holding the cable.
  9. Asus 1015E-DS03 Keyboard Replacement: 9 단계, 이미지 1/2 Asus 1015E-DS03 Keyboard Replacement: 9 단계, 이미지 2/2
    • Gently pull the strip out of the square slot.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Joe Capriola
회원 가입일: 03/21/16
428 평판
안내서 3개 작성하였습니다
Clemson, Team 7-4, Benson Spring 2016 Clemson, Team 7-4, Benson Spring 2016 회원
CLEM-BENSON-S16S7G4
5 회원들
안내서 7개 작성하였습니다
0 Comments
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 4
전체 시간: 909
