주요 콘텐츠로 건너뛰기
Asus 1015E-DS03 Screen Replacement
필요한 것
  1. Asus 1015E-DS03 Screen Replacement, Battery: 1 단계, 이미지 1/1
    • Hold the laptop using both hands with the battery facing upwards.
  2. Asus 1015E-DS03 Screen Replacement: 2 단계, 이미지 1/1
    • Push the two tabs located below the battery in towards each other using your thumbs.
  3. Asus 1015E-DS03 Screen Replacement: 3 단계, 이미지 1/1
    • Push the battery upwards and out of the laptop as shown.
  4. Asus 1015E-DS03 Screen Replacement: 4 단계, 이미지 1/1
    • Continue to push the battery upwards until it is completely separated from the laptop as shown.
  5. Asus 1015E-DS03 Screen Replacement, Front Screen Case: 5 단계, 이미지 1/1
    • Push up on the back of the tabs that cover the hinges connecting the screen to the base of the laptop.
    • While pushing up on the back of the tabs, insert the spudger into the opening created from pushing on the tabs until the tab detaches.
  6. Asus 1015E-DS03 Screen Replacement: 6 단계, 이미지 1/2 Asus 1015E-DS03 Screen Replacement: 6 단계, 이미지 2/2
    • Once the case has been separated from the laptop, pull the case off completely, using the plastic opening tool or your fingers.
    • You will hear popping noises which are to be expected.
  7. Asus 1015E-DS03 Screen Replacement: 7 단계, 이미지 1/1
    • When the screen case has been successfully removed, the laptop should resemble the photo shown here.
  8. Asus 1015E-DS03 Screen Replacement, Screen: 8 단계, 이미지 1/1
    • Unscrew the 3 mm screws (4) using a #0 Phillips head screwdriver.
  9. Asus 1015E-DS03 Screen Replacement: 9 단계, 이미지 1/2 Asus 1015E-DS03 Screen Replacement: 9 단계, 이미지 2/2
    • Lift the screen away from the computer.
    • Be careful removing the screen, as the left side is still connected to the computer.
  10. Asus 1015E-DS03 Screen Replacement: 10 단계, 이미지 1/2 Asus 1015E-DS03 Screen Replacement: 10 단계, 이미지 2/2
    • Remove the wire that is glued to the back of the screen with your fingers.
    • Remove the tape covering the connection port.
  11. Asus 1015E-DS03 Screen Replacement: 11 단계, 이미지 1/1
    • Separate the screen from the computer by gently pulling it out.
  12. Asus 1015E-DS03 Screen Replacement: 12 단계, 이미지 1/1
    • Upon removal, the computer should look like this picture.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Becca Day
회원 가입일: 03/23/16
297 평판
안내서 2개 작성하였습니다
Clemson, Team 7-4, Benson Spring 2016 Clemson, Team 7-4, Benson Spring 2016 회원
CLEM-BENSON-S16S7G4
5 회원들
안내서 7개 작성하였습니다
0 Comments
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 529
