필요한 것
Remove screws at the circles
Remove gum strap and screw 5 screws out
Use a big screwdriver or some plastic to softly open the entire case around, starting at one down corner where your removed the screws before. The plastic clips will click a little. Don't be to hard.
Then you can lay the back next to the front, see second picture.
거의 끝나갑니다!
결론
다른 한 분이 해당 안내서를 완성하였습니다.
