소개
This guide will teach you how to open the laptop with a screwdriver, identify and safely remove the broken WiFi card, and replace it with a working one.
필요한 것
Place the laptop face down with the battery facing away from you.
Locate the two buttons next to the battery.
Slide the right slider to the unlocked (red) position.
Remove the five Phillips # 0 screws from the back panel.
Using your finger or a plastic spudger start to carefully pry up the back planel.
First, find the Wi-Fi card
Move the protective flap back and use a Phillips size 0 screw driver to remove the two screws.
다른 한 분이 해당 안내서를 완성하였습니다.
