주요 콘텐츠로 건너뛰기
Asus A53E-ES92 Hard Drive Replacement
필요한 것
  1. Asus A53E-ES92 Hard Drive Replacement, Hard Drive: 1 단계, 이미지 1/1
    • Turn laptop over to expose the bottom panel
  2. Asus A53E-ES92 Hard Drive Replacement: 2 단계, 이미지 1/2 Asus A53E-ES92 Hard Drive Replacement: 2 단계, 이미지 2/2
    • Use a Phillips #0 screwdriver to remove the two screws circled in picture.
  3. Asus A53E-ES92 Hard Drive Replacement: 3 단계, 이미지 1/3 Asus A53E-ES92 Hard Drive Replacement: 3 단계, 이미지 2/3 Asus A53E-ES92 Hard Drive Replacement: 3 단계, 이미지 3/3
    • Place fingers on panel as shown below.
    • Apply slight force while gently sliding the panel away from the laptop.
    • Remove panel.
  4. Asus A53E-ES92 Hard Drive Replacement: 4 단계, 이미지 1/2 Asus A53E-ES92 Hard Drive Replacement: 4 단계, 이미지 2/2
    • Locate hard drive, circled in red.
  5. Asus A53E-ES92 Hard Drive Replacement: 5 단계, 이미지 1/2 Asus A53E-ES92 Hard Drive Replacement: 5 단계, 이미지 2/2
    • Remove the four screws with a Phillips #0 screwdriver.
  6. Asus A53E-ES92 Hard Drive Replacement: 6 단계, 이미지 1/3 Asus A53E-ES92 Hard Drive Replacement: 6 단계, 이미지 2/3 Asus A53E-ES92 Hard Drive Replacement: 6 단계, 이미지 3/3
    • Apply slight pressure on the hard drive.
    • Slide hard drive to the left to unlock it.
  7. Asus A53E-ES92 Hard Drive Replacement: 7 단계, 이미지 1/1
    • Remove the hard drive from the device.
결론
Robyn Lam
회원 가입일: 10/22/18
695 평판
안내서 4개 작성하였습니다
UC Davis, Team S11-G7, Lore Fall 2018 UC Davis, Team S11-G7, Lore Fall 2018 회원
UCD-LORE-F18S11G7
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 8
30일 전: 44
전체 시간: 1,003
