주요 콘텐츠로 건너뛰기
Asus A53S Fan Assembly Replacement
필요한 것
  1. Asus A53S Fan Assembly Replacement, Motherboard: 1 단계, 이미지 1/3 Asus A53S Fan Assembly Replacement, Motherboard: 1 단계, 이미지 2/3 Asus A53S Fan Assembly Replacement, Motherboard: 1 단계, 이미지 3/3
    • Power off your device and remove the battery before beginning this guide.
    • Flip the laptop so the underside is facing up.
    • Using a Phillips #01 screwdriver, unscrew the two 6 mm screws.
  2. Asus A53S Fan Assembly Replacement: 2 단계, 이미지 1/2 Asus A53S Fan Assembly Replacement: 2 단계, 이미지 2/2
    • Place a spudger under the white wire and pull it up gently, disconnecting it from the Wi-Fi card.
    • Use the same method on the black wire.
  3. Asus A53S Fan Assembly Replacement: 3 단계, 이미지 1/3 Asus A53S Fan Assembly Replacement: 3 단계, 이미지 2/3 Asus A53S Fan Assembly Replacement: 3 단계, 이미지 3/3
    • Push the hard drive to the left and remove it.
  4. Asus A53S Fan Assembly Replacement: 4 단계, 이미지 1/2 Asus A53S Fan Assembly Replacement: 4 단계, 이미지 2/2
    • Using a Phillips #01 screwdriver, unscrew the fifteen 6 mm screws.
  5. Asus A53S Fan Assembly Replacement: 5 단계, 이미지 1/2 Asus A53S Fan Assembly Replacement: 5 단계, 이미지 2/2
    • Flip over the laptop and open it.
    • Using the spudger, insert the flat end into the notches at the top of the keyboard and slowly "pop" the keyboard up and out of the device.
  6. Asus A53S Fan Assembly Replacement: 6 단계, 이미지 1/2 Asus A53S Fan Assembly Replacement: 6 단계, 이미지 2/2
    • Using the flat end of the spudger, lift the black ZIF connector lock bar and disconnect the keyboard from the computer.
    • Remove the keyboard.
  7. Asus A53S Fan Assembly Replacement: 7 단계, 이미지 1/2 Asus A53S Fan Assembly Replacement: 7 단계, 이미지 2/2
    • Using the spudger, place the flat end under the black lock bar holding the power switch. Push the spudger up and to the left, disconnecting the power switch.
    • Use the same technique on the touchpad to disconnect it.
  8. Asus A53S Fan Assembly Replacement: 8 단계, 이미지 1/2 Asus A53S Fan Assembly Replacement: 8 단계, 이미지 2/2
    • Using a Phillips #01 screwdriver, unscrew the seven 6 mm screws.
  9. Asus A53S Fan Assembly Replacement: 9 단계, 이미지 1/1
    • Gently pull out the optical drive.
  10. Asus A53S Fan Assembly Replacement: 10 단계, 이미지 1/1
    • Flip the laptop back over so that the bottom is facing up.
    • Use a Phillips #01 screwdriver to unscrew the three 6 mm screws.
  11. Asus A53S Fan Assembly Replacement: 11 단계, 이미지 1/2 Asus A53S Fan Assembly Replacement: 11 단계, 이미지 2/2
    • Turn the laptop back over so that you can open it.
    • Gently separate the cover from the laptop by putting an opening tool between the cover and the lower part of the laptop.
  12. Asus A53S Fan Assembly Replacement: 12 단계, 이미지 1/1
    • Remove the yellow tape.
  13. Asus A53S Fan Assembly Replacement: 13 단계, 이미지 1/1
    • Using the flat end of a spudger, flip ZIF connector lock bar up, disconnecting the USB board from the mother board.
  14. Asus A53S Fan Assembly Replacement: 14 단계, 이미지 1/2 Asus A53S Fan Assembly Replacement: 14 단계, 이미지 2/2
    • Using the pointy end of a spudger, push upwards on the notches of the tan part of the LCD connector.
  15. Asus A53S Fan Assembly Replacement: 15 단계, 이미지 1/2 Asus A53S Fan Assembly Replacement: 15 단계, 이미지 2/2
    • Using the pointy end of a spudger, gently push upwards on the black part of the speaker connector.
  16. Asus A53S Fan Assembly Replacement: 16 단계, 이미지 1/2 Asus A53S Fan Assembly Replacement: 16 단계, 이미지 2/2
    • Using a Phillips #01 screwdriver, unscrew the five 6 mm screws at the indicated places.
    • Using a Phillips #01 screwdriver, unscrew the 5 mm screws.
    • All of these screws are indicated by a small white arrow.
  17. Asus A53S Fan Assembly Replacement: 17 단계, 이미지 1/2 Asus A53S Fan Assembly Replacement: 17 단계, 이미지 2/2
    • Gently lift the motherboard, removing it from the laptop shell.
  18. Asus A53S Fan Assembly Replacement, Fan Assembly: 18 단계, 이미지 1/3 Asus A53S Fan Assembly Replacement, Fan Assembly: 18 단계, 이미지 2/3 Asus A53S Fan Assembly Replacement, Fan Assembly: 18 단계, 이미지 3/3
    • Flip the motherboard so that the fan and heat sink are facing up.
    • Pinch the upper part of the connector and pull upwards, slightly shimmying it side to side, to disconnect the fan.
  19. Asus A53S Fan Assembly Replacement: 19 단계, 이미지 1/3 Asus A53S Fan Assembly Replacement: 19 단계, 이미지 2/3 Asus A53S Fan Assembly Replacement: 19 단계, 이미지 3/3
    • Using a Phillips #01 screwdriver, unscrew the seven 5 mm screws.
    • Remove the fan assembly.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Ethan Martins
회원 가입일: 09/22/22
115 평판
안내서 1개 작성함
University of North Texas, Team 3-1, Saru Jimmy Fall 2022 University of North Texas, Team 3-1, Saru Jimmy Fall 2022 회원
UNT-SARU JIMMY-F22S3G1
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 3
30일 전: 26
전체 시간: 315
