소개
Is your computer heating up quickly or making loud noises? Consider using this guide to replace the fan in your device.
필요한 것
Remove the 5mm screw using a Phillips #1 screwdriver.
Use the iFixit opening tools to remove the RAM panel.
Remove the RAM cover from the bottom of the keyboard.
Remove the 5mm screw keeping the panel in place using a Phillips #1 screwdriver.
Work the pry tool along the edge to finish removal.
Unscrew the two 7mm screws marked with an engraved "K" using a #1 Phillips screwdriver.
Close the laptop and place it upside down.
Remove the twelve 7mm screws using a Phillips #1 screwdriver.
To remove the heat sink, unscrew the four 7mm screws using a Phillips #1 screwdriver.
Remove the heatsink from the device.
