소개
The heat sink and the fan assembly are attached directly to the CPU of the laptop to keep it as cool as possible during operation. If the fan stops working, or the heat sink somehow becomes damaged or unattached, the CPU runs a dangerous risk of overheating and becoming permanently damaged. This guide will walk you through replacing the heat sink of your device.
필요한 것
Remove the 5mm screw using a Phillips #1 screwdriver.
Use the iFixit opening tools to remove the RAM panel.
Remove the RAM cover from the bottom of the keyboard.
Remove the 5mm screw keeping the panel in place using a Phillips #1 screwdriver.
Work the pry tool along the edge to finish removal.
Unscrew the two 7mm screws marked with an engraved "K" using a #1 Phillips screwdriver.
Close the laptop and place it upside down.
Remove the twelve 7mm screws using a Phillips #1 screwdriver.
To remove the heat sink, unscrew the four 7mm screws using a Phillips #1 screwdriver.
Remove the heatsink from the device.
