주요 콘텐츠로 건너뛰기
Asus A53U-ES21 Optical Drive Replacement
필요한 것
  1. Asus A53U-ES21 Optical Drive Replacement, Battery: 1 단계, 이미지 1/2 Asus A53U-ES21 Optical Drive Replacement, Battery: 1 단계, 이미지 2/2
    • Make sure the laptop is off.
    • Flip the laptop upside down so that the battery is facing you.
  2. Asus A53U-ES21 Optical Drive Replacement: 2 단계, 이미지 1/2 Asus A53U-ES21 Optical Drive Replacement: 2 단계, 이미지 2/2
    • Move the two sliders towards the outer edge of the laptop.
    • Pull the battery out with your left hand while holding the right slider.
  3. Asus A53U-ES21 Optical Drive Replacement, Optical Drive: 3 단계, 이미지 1/3 Asus A53U-ES21 Optical Drive Replacement, Optical Drive: 3 단계, 이미지 2/3 Asus A53U-ES21 Optical Drive Replacement, Optical Drive: 3 단계, 이미지 3/3
    • Remove the 5mm screw using a Phillips #1 screwdriver.
    • Use the iFixit opening tools to remove the RAM panel.
  4. Asus A53U-ES21 Optical Drive Replacement: 4 단계, 이미지 1/3 Asus A53U-ES21 Optical Drive Replacement: 4 단계, 이미지 2/3 Asus A53U-ES21 Optical Drive Replacement: 4 단계, 이미지 3/3
    • Remove the 7mm screw using a Phillips #1 screwdriver.
    • Pull the optical drive out from the side of the laptop.
결론
Chase Poirier
회원 가입일: 10/23/18
544 평판
안내서 5개 작성하였습니다
UMass Dartmouth, Team S1-G3, Simcock Fall 2018 UMass Dartmouth, Team S1-G3, Simcock Fall 2018 회원
UMASSD-SIMCOCK-F18S1G3
3 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 267
