주요 콘텐츠로 건너뛰기
Asus Chromebook C101P Speakers Replacement
필요한 것
  1. Asus Chromebook C101P Speakers Replacement, Keyboard: 1 단계, 이미지 1/1
    • Flip the Chromebook so that the bottom is facing up.
    • Remove the nine T5 Torx screws.
  2. Asus Chromebook C101P Speakers Replacement: 2 단계, 이미지 1/1
    • Remove the four rubber grips on the bottom side of the Chromebook using an opening tool.
  3. Asus Chromebook C101P Speakers Replacement: 3 단계, 이미지 1/1
    • Remove the four black screws where the rubber grips were.
  4. Asus Chromebook C101P Speakers Replacement: 4 단계, 이미지 1/2 Asus Chromebook C101P Speakers Replacement: 4 단계, 이미지 2/2
    • Reorient the Chromebook so the right side is facing upwards.
    • Wedge an opening tool or spudger between the keyboard (upper case) and the lower case of the bottom portion of the Chromebook.
  5. Asus Chromebook C101P Speakers Replacement: 5 단계, 이미지 1/3 Asus Chromebook C101P Speakers Replacement: 5 단계, 이미지 2/3 Asus Chromebook C101P Speakers Replacement: 5 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Pull back the black lever on the base of the cable. While pulling back, take your tweezers and pull back on the large ribbon cable.
    • Pull back the black lever on the base of the cable. While pulling back, take your tweezers and pull back on the small ribbon cable.
    • Separate the keyboard from the rest of the laptop.
  6. Asus Chromebook C101P Speakers Replacement, Speakers: 6 단계, 이미지 1/1
    • Remove the four Phillips #0 screws from the speakers.
  7. Asus Chromebook C101P Speakers Replacement: 7 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Remove the yellow speaker tape using tweezers.
  8. Asus Chromebook C101P Speakers Replacement: 8 단계, 이미지 1/2 Asus Chromebook C101P Speakers Replacement: 8 단계, 이미지 2/2
    • Detach the right speaker using tweezers.
    • The right speaker has its own set of cables connecting to the motherboard. Simply tug on the cables.
결론
Bryan Acosta
회원 가입일: 10/25/19
329 평판
안내서 3개 작성하였습니다
UMass Dartmouth, Team S1-G2, O'Connell Fall 2019 UMass Dartmouth, Team S1-G2, O'Connell Fall 2019 회원
UMASSD-O'CONNELL-F19S1G2
2 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 7
전체 시간: 399
