주요 콘텐츠로 건너뛰기
Asus Chromebook C201 LCD Screen Replacement
필요한 것
  1. Asus Chromebook C201 LCD Screen Replacement, Palm Rest Assembly: 1 단계, 이미지 1개 중 1개
    • Flip the laptop upside down with the rear end of the computer away from you.
  2. Asus Chromebook C201 LCD Screen Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the two rear rubber feet by using one of the small, blue plastic spudgers.
  3. Asus Chromebook C201 LCD Screen Replacement: 3 단계, 이미지 1개 중 1개
    • Use the J0 screwdriver to remove the eight 5mm black screws on the bottom of the laptop, which includes the two that were hidden under the rear rubber feet.
  4. Asus Chromebook C201 LCD Screen Replacement: 4 단계, 이미지 1개 중 1개
    • Turn the laptop on its side. Use a small, blue opening tool to pry the keyboard cover and laptop apart. Begin from the top right, next to the power button, and slowly work your way around to the opposite side until the keyboard cover is detached.
  5. Asus Chromebook C201 LCD Screen Replacement: 5 단계, 이미지 2개 중 1개 Asus Chromebook C201 LCD Screen Replacement: 5 단계, 이미지 2개 중 2개
    • Gently flip the keyboard cover away from the laptop. Rest it safely upside down so the cables are not strained and are easily accessible.
  6. Asus Chromebook C201 LCD Screen Replacement: 6 단계, 이미지 3개 중 1개 Asus Chromebook C201 LCD Screen Replacement: 6 단계, 이미지 3개 중 2개 Asus Chromebook C201 LCD Screen Replacement: 6 단계, 이미지 3개 중 3개
    • Use the metal spudger to gently pry up the small tabs that are clamping down on the keyboard cables.
  7. Asus Chromebook C201 LCD Screen Replacement: 7 단계, 이미지 2개 중 1개 Asus Chromebook C201 LCD Screen Replacement: 7 단계, 이미지 2개 중 2개
    • Carefully pull the keyboard cables out of the connecting ports that are attached to the motherboard.
  8. Asus Chromebook C201 LCD Screen Replacement: 8 단계, 이미지 1개 중 1개
    • Remove the keyboard cover and safely place it somewhere face down.
  9. Asus Chromebook C201 LCD Screen Replacement, LCD Screen: 9 단계, 이미지 2개 중 1개 Asus Chromebook C201 LCD Screen Replacement, LCD Screen: 9 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Locate the LCD cable and its connector which is located in the upper left hand corner of the computer. Carefully flip up the tiny tab and safely remove the cable using precision tweezers.
  10. Asus Chromebook C201 LCD Screen Replacement: 10 단계, 이미지 2개 중 1개 Asus Chromebook C201 LCD Screen Replacement: 10 단계, 이미지 2개 중 2개
    • Disconnect the black and white cables located near the screen hinge.
  11. Asus Chromebook C201 LCD Screen Replacement: 11 단계, 이미지 2개 중 1개 Asus Chromebook C201 LCD Screen Replacement: 11 단계, 이미지 2개 중 2개
    • Remove the 6, 4mm silver screws from the hinges attaching the LCD to the laptop using the J0 Phillips screwdriver.
  12. Asus Chromebook C201 LCD Screen Replacement: 12 단계, 이미지 1개 중 1개
    • Turn the hinges to an upright position.
  13. Asus Chromebook C201 LCD Screen Replacement: 13 단계, 이미지 2개 중 1개 Asus Chromebook C201 LCD Screen Replacement: 13 단계, 이미지 2개 중 2개
    • Carefully pop the LCD screen assembly out of the laptop case.
  14. Asus Chromebook C201 LCD Screen Replacement: 14 단계, 이미지 2개 중 1개 Asus Chromebook C201 LCD Screen Replacement: 14 단계, 이미지 2개 중 2개
    • Remove the silver cover.
    • Make sure to put the cover back in right side (longer side) up when re-installing
  15. Asus Chromebook C201 LCD Screen Replacement: 15 단계, 이미지 2개 중 1개 Asus Chromebook C201 LCD Screen Replacement: 15 단계, 이미지 2개 중 2개
    • Use a blue plastic spudger to snap the LCD cover off, working the spudger around the perimeter and completely remove the cover.
  16. Asus Chromebook C201 LCD Screen Replacement: 16 단계, 이미지 1개 중 1개
    • Remove the 4, 3mm silver corner screws holding in the LCD.
  17. Asus Chromebook C201 LCD Screen Replacement: 17 단계, 이미지 2개 중 1개 Asus Chromebook C201 LCD Screen Replacement: 17 단계, 이미지 2개 중 2개
    • Remove the left hinge by unscrewing the two 3mm large Phillips head screws.
    • Unscrew the one 3mm small Phillips head screw.
  18. Asus Chromebook C201 LCD Screen Replacement: 18 단계, 이미지 2개 중 1개 Asus Chromebook C201 LCD Screen Replacement: 18 단계, 이미지 2개 중 2개
    • Carefully lift the screen. Gently unravel and unplug the LCD cord.
결론
다른 10명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Taylor Allen
회원 가입일: 02/09/16
327 평판
안내서 1개를 작성함
USF Tampa, Team 2-51, Cagle Spring 2016 USF Tampa, Team 2-51, Cagle Spring 2016 회원
USFT-CAGLE-S16S2G51
4 회원들
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 13
전체 시간: 3,849
