주요 콘텐츠로 건너뛰기
Asus Chromebook C201 Motherboard Replacement
필요한 것
  1. Asus Chromebook C201 Motherboard Replacement, Palm Rest Assembly: 1 단계, 이미지 1/1
    • Flip the laptop upside down with the rear end of the computer away from you.
  2. Asus Chromebook C201 Motherboard Replacement: 2 단계, 이미지 1/1
    • Remove the two rear rubber feet by using one of the small, blue plastic spudgers.
  3. Asus Chromebook C201 Motherboard Replacement: 3 단계, 이미지 1/1
    • Use the J0 screwdriver to remove the eight 5mm black screws on the bottom of the laptop, which includes the two that were hidden under the rear rubber feet.
  4. Asus Chromebook C201 Motherboard Replacement: 4 단계, 이미지 1/1
    • Turn the laptop on its side. Use a small, blue opening tool to pry the keyboard cover and laptop apart. Begin from the top right, next to the power button, and slowly work your way around to the opposite side until the keyboard cover is detached.
  5. Asus Chromebook C201 Motherboard Replacement: 5 단계, 이미지 1/2 Asus Chromebook C201 Motherboard Replacement: 5 단계, 이미지 2/2
    • Gently flip the keyboard cover away from the laptop. Rest it safely upside down so the cables are not strained and are easily accessible.
  6. Asus Chromebook C201 Motherboard Replacement: 6 단계, 이미지 1/3 Asus Chromebook C201 Motherboard Replacement: 6 단계, 이미지 2/3 Asus Chromebook C201 Motherboard Replacement: 6 단계, 이미지 3/3
    • Use the metal spudger to gently pry up the small tabs that are clamping down on the keyboard cables.
  7. Asus Chromebook C201 Motherboard Replacement: 7 단계, 이미지 1/2 Asus Chromebook C201 Motherboard Replacement: 7 단계, 이미지 2/2
    • Carefully pull the keyboard cables out of the connecting ports that are attached to the motherboard.
  8. Asus Chromebook C201 Motherboard Replacement: 8 단계, 이미지 1/1
    • Remove the keyboard cover and safely place it somewhere face down.
  9. Asus Chromebook C201 Motherboard Replacement, Motherboard: 9 단계, 이미지 1/1
    • Use tweezers to disconnect the LCD cable from the motherboard.
  10. Asus Chromebook C201 Motherboard Replacement: 10 단계, 이미지 1/1
    • Use the tweezers to disconnect both wifi antenna cables from the motherboard.
  11. Asus Chromebook C201 Motherboard Replacement: 11 단계, 이미지 1/2 Asus Chromebook C201 Motherboard Replacement: 11 단계, 이미지 2/2
    • Use a J0 Phillips screwdriver to remove the 6, 4mm small head silver screws.
    • Use the same J0 Phillips screwdriver to remove the 4mm large head silver screw from the head shield.
    • Remove the heat shield.
  12. Asus Chromebook C201 Motherboard Replacement: 12 단계, 이미지 1/1
    • Use the tweezers to disconnect the battery cable from the motherboard.
  13. Asus Chromebook C201 Motherboard Replacement: 13 단계, 이미지 1/1
    • Use the tweezers to disconnect the daughterboard plug from the motherboard.
  14. Asus Chromebook C201 Motherboard Replacement: 14 단계, 이미지 1/2 Asus Chromebook C201 Motherboard Replacement: 14 단계, 이미지 2/2
    • Remove the sound cable from motherboard.
  15. Asus Chromebook C201 Motherboard Replacement: 15 단계, 이미지 1/1
    • Use a J0 Phillips screwdriver to remove the single, silver, 4mm screw on the motherboard.
  16. Asus Chromebook C201 Motherboard Replacement: 16 단계, 이미지 1/1
    • Remove the motherboard.
결론
다른 7명이 해당 안내서를 완성하였습니다.
Bryan Franz
회원 가입일: 02/09/16
476 평판
안내서 1개 작성함
USF Tampa, Team 2-51, Cagle Spring 2016 USF Tampa, Team 2-51, Cagle Spring 2016 회원
USFT-CAGLE-S16S2G51
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 8
전체 시간: 3,184
