소개
If your Chromebook is not working correctly, then this guide is going to help you get your laptop working again. When working on replacing your motherboard, be sure to ground yourself. Static can short circuit your Chromebook, so be sure to either wear an anti-static wrist strap or work on a surface that doesn't generate static electricity, like wood, tile, or other hard floors.
필요한 것
Flip the laptop upside down with the rear end of the computer away from you.
다른 7명이 해당 안내서를 완성하였습니다.
