주요 콘텐츠로 건너뛰기
Asus Chromebook C201 Trackpad Replacement
필요한 것
  1. Asus Chromebook C201 Trackpad Replacement, Trackpad: 1 단계, 이미지 1/1
    • First, flip over the chromebook.
  2. Asus Chromebook C201 Trackpad Replacement: 2 단계, 이미지 1/1
    • Then, pull off the plastic sliders on either side of the bottom of the computer using the spludger.
  3. Asus Chromebook C201 Trackpad Replacement: 3 단계, 이미지 1/1
    • Unscrew all of the screws in the back of the computer. Use a Phillips 1 screwdriver to remove the 8 1/2cm screws.
  4. Asus Chromebook C201 Trackpad Replacement: 4 단계, 이미지 1/1
    • Turn the computer onto its side. Then, use a plastic opening tool to open the gap between the keyboard and the rest of the computer by slipping it between the two panels making up the body of the computer.
  5. Asus Chromebook C201 Trackpad Replacement: 5 단계, 이미지 1/1
    • Slide the plastic opening tool around the length of the keyboard to free it from the laptop. Once the keyboard is free of the computer, lift the keyboard up gently until you can see and reach the two wires attaching it to the computer.
  6. Asus Chromebook C201 Trackpad Replacement: 6 단계, 이미지 1/1
    • Lift up the retaining flaps on the keyboard and trackpad ZIF connectors.
    • Gently pull the trackpad and keyboard ribbon cables out of their sockets on the motherboard.
  7. Asus Chromebook C201 Trackpad Replacement: 7 단계, 이미지 1/1
    • Take the keyboard off of the computer and flip it over.
  8. Asus Chromebook C201 Trackpad Replacement: 8 단계, 이미지 1/1
    • Unscrew the 2/10 cm screws holding the trackpad onto the keyboard using a Phillips head #000 screwdriver.
  9. Asus Chromebook C201 Trackpad Replacement: 9 단계, 이미지 1/1
    • Gently pry up the trackpad with a plastic opening tool. gently tilt the trackpad out of its slot and pull the trackpad out of the keyboard at an angle away from the slot.
  10. Asus Chromebook C201 Trackpad Replacement: 10 단계, 이미지 1/1
    • Place new trackpad into slot at an angle. Gently push new trackpad into the slot and press down on it very gently to make sure that it is completely in the slot.
  11. Asus Chromebook C201 Trackpad Replacement: 11 단계, 이미지 1/1
    • Press the silver tabs onto board where they fall.
  12. Asus Chromebook C201 Trackpad Replacement: 12 단계, 이미지 1/1
    • Screw in 2/10 cm screws to hold the trackpad onto the keyboard using a Phillips head #000 screwdriver.
  13. Asus Chromebook C201 Trackpad Replacement: 13 단계, 이미지 1/2 Asus Chromebook C201 Trackpad Replacement: 13 단계, 이미지 2/2
    • Plug wires on keyboard back into their ports.
    • It may take a few tries to plug the wires back into the ports, because they use a tricky flap that snaps over the wire once you put it in place. Pull up the flap, place the wire fully onto the port, and snap the flap onto the wire.
  14. Asus Chromebook C201 Trackpad Replacement: 14 단계, 이미지 1/1
    • Snap keyboard back into place.
  15. Asus Chromebook C201 Trackpad Replacement: 15 단계, 이미지 1/1
    • Screw all 1/2 cm screws back into place using the Phillips head #1, and push the plastic sliders back into their slots.
결론
Your replacement is now complete and your trackpad is as good as new... because it is new!
다른 한 분이 해당 안내서를 완성하였습니다.
Samuel Farone
회원 가입일: 06/01/16
141 평판
안내서 1개 작성함
댓글 한 개
where can i get the replacement track pad
broskie gang - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 8
전체 시간: 949
