주요 콘텐츠로 건너뛰기
Asus Chromebook C201PA-DS02-LG Battery Replacement
필요한 것
  1. Asus Chromebook C201PA-DS02-LG Battery Replacement, Keyboard: 1 단계, 이미지 1/3 Asus Chromebook C201PA-DS02-LG Battery Replacement, Keyboard: 1 단계, 이미지 2/3 Asus Chromebook C201PA-DS02-LG Battery Replacement, Keyboard: 1 단계, 이미지 3/3
    • Use a metal spudger to pry off the two feet closest to the hinge of the laptop.
    • The feet are attached to the laptop by adhesives, therefore they may not stick as well after multiple removals.
  2. Asus Chromebook C201PA-DS02-LG Battery Replacement: 2 단계, 이미지 1/2 Asus Chromebook C201PA-DS02-LG Battery Replacement: 2 단계, 이미지 2/2
    • Use a Phillips #0 screwdriver to unscrew the six 5mm screws.
    • Use a Phillips #0 screwdriver to unscrew the two 6mm screws.
  3. Asus Chromebook C201PA-DS02-LG Battery Replacement: 3 단계, 이미지 1/2 Asus Chromebook C201PA-DS02-LG Battery Replacement: 3 단계, 이미지 2/2
    • Use a plastic opening tool to pry the keyboard off the edges of the computer.
    • The edges will make a popping noise.
  4. Asus Chromebook C201PA-DS02-LG Battery Replacement: 4 단계, 이미지 1/3 Asus Chromebook C201PA-DS02-LG Battery Replacement: 4 단계, 이미지 2/3 Asus Chromebook C201PA-DS02-LG Battery Replacement: 4 단계, 이미지 3/3
    • Flip up the white bar that connects the thin white strip using a plastic opening tool.
    • Grab the thin white strip and pull straight back to remove the strip from the connector.
  5. Asus Chromebook C201PA-DS02-LG Battery Replacement: 5 단계, 이미지 1/3 Asus Chromebook C201PA-DS02-LG Battery Replacement: 5 단계, 이미지 2/3 Asus Chromebook C201PA-DS02-LG Battery Replacement: 5 단계, 이미지 3/3
    • Use a plastic opening tool to lift the black bar above the wide black strip in the connector.
    • Grab the wide black strip and pull straight back to remove the strip from the connector.
    • Remove the keyboard by lifting it straight up.
  6. Asus Chromebook C201PA-DS02-LG Battery Replacement, Metal Plate: 6 단계, 이미지 1/3 Asus Chromebook C201PA-DS02-LG Battery Replacement, Metal Plate: 6 단계, 이미지 2/3 Asus Chromebook C201PA-DS02-LG Battery Replacement, Metal Plate: 6 단계, 이미지 3/3
    • Unscrew the seven 4mm screws using a Phillips #0 screwdriver.
    • Wiggle the plate back and forth to loosen the adhesive under the plate.
    • The adhesive will not be the same after removal and more adhesive may be necessary upon reassembly.
    • Rotate the screwdriver in a counterclockwise direction to remove the screws.
    • Do not rest your arm or hand in the adhesive.
  7. Asus Chromebook C201PA-DS02-LG Battery Replacement, Battery: 7 단계, 이미지 1/3 Asus Chromebook C201PA-DS02-LG Battery Replacement, Battery: 7 단계, 이미지 2/3 Asus Chromebook C201PA-DS02-LG Battery Replacement, Battery: 7 단계, 이미지 3/3
    • Use a Phillips #0 screwdriver to unscrew the 4mm screws. Rotate the screwdriver in a counterclockwise direction to undo the screws.
    • Remove the rainbow connector by firmly grasping the rainbow wires and pulling straight back. It will help to brace the motherboard when you pull.
  8. Asus Chromebook C201PA-DS02-LG Battery Replacement: 8 단계, 이미지 1/2 Asus Chromebook C201PA-DS02-LG Battery Replacement: 8 단계, 이미지 2/2
    • Use the plastic opening tool to lift up the battery and remove it.
    • Do not dispose of the battery in normal waste. The chemicals inside are toxic. Find out where to dispose of properly in your neighborhood.
결론
Ashley Humpal
회원 가입일: 04/18/18
185 평판
안내서 1개 작성함
Cal Poly, Team S17-G4, Livingston Spring 2018 Cal Poly, Team S17-G4, Livingston Spring 2018 회원
CPSU-LIVINGSTON-S18S17G4
4 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 13
전체 시간: 356
