주요 콘텐츠로 건너뛰기
Asus Chromebook C202 Keyboard Replacement
필요한 것
  1. Asus Chromebook C202 Keyboard Replacement, Palm Rest: 1 단계, 이미지 1/1
    • Turn the device over so the bottom is facing up.
    • Remove the ten Phillips #1 8.0 mm screws.
  2. Asus Chromebook C202 Keyboard Replacement: 2 단계, 이미지 1/2 Asus Chromebook C202 Keyboard Replacement: 2 단계, 이미지 2/2
    • Carefully use the plastic opening tool to pry the palm rest apart from the bottom cover. Start from one spot and systematically work your way around until the whole palm rest is detached.
  3. Asus Chromebook C202 Keyboard Replacement: 3 단계, 이미지 1/1
    • Disconnect the two cables that run from the keyboard to the motherboard and from the touch pad to the motherboard.
    • You may have to use a spudger to lift open the respective latches.
  4. Asus Chromebook C202 Keyboard Replacement, Keyboard: 4 단계, 이미지 1/1
    • Once the cables are disconnected, remove the keyboard from the back panel.
    • Now that the keyboard is disconnected, you can replace it with a new one.
결론
Noah Helms
회원 가입일: 10/03/19
73 평판
안내서 1개 작성함
댓글 한 개
Is it easy if your replacement keyboard doesn't include the frame? How does the frame attach to the keyboard?
Alexander Pruss - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 11
30일 전: 69
전체 시간: 1,812
