주요 콘텐츠로 건너뛰기
Asus Chromebook C202 Motherboard Replacement
필요한 것
  1. Asus Chromebook C202 Motherboard Replacement, Back Panel: 1 단계, 이미지 1/2 Asus Chromebook C202 Motherboard Replacement, Back Panel: 1 단계, 이미지 2/2
    이 단계에 사용된 도구:
    Phillips #1 Screwdriver
    $5.49
    구매
    • Remove ten 8 mm Phillips #1 screws from the bottom of the Chromebook using a Phillips #1 screwdriver.
    • Two of the screws are hidden by rubber caps along the rubber rest of the device. Use tweezers to get them out.
  2. Asus Chromebook C202 Motherboard Replacement: 2 단계, 이미지 1/1
    이 단계에 사용된 도구:
    iFixit Opening Tool
    $1.99
    구매
    • Place the plastic opening tool into the edges between the front of the Chromebook and the back of it with the upper scoop of the opening tool facing upward.
    • Push down on the plastic opening tool to unhinge the top portion of the Chromebook from its lower portion. Opening the Chromebook all the way where the display touches the ground helps in opening up the top edge.
    • Use your hand to gently lift the top portion of the Chromebook from the bottom portion of it to avoid damaging the ribbon cables.
  3. Asus Chromebook C202 Motherboard Replacement: 3 단계, 이미지 1/1
    • Gently disconnect the ribbon cable connecting the trackpad to the motherboard.
    • Gently disconnect the ribbon cable connecting the keyboard to the motherboard.
  4. Asus Chromebook C202 Motherboard Replacement, Wireless Card: 4 단계, 이미지 1/1
    • Remove the black and white wires from the wireless card.
  5. Asus Chromebook C202 Motherboard Replacement: 5 단계, 이미지 1/1
    • Unscrew the single 4 mm Phillips #1 screw pinning the wireless card in place.
  6. Asus Chromebook C202 Motherboard Replacement: 6 단계, 이미지 1/1
    • Gently pull the wireless card away from the motherboard.
  7. Asus Chromebook C202 Motherboard Replacement, Battery: 7 단계, 이미지 1/3 Asus Chromebook C202 Motherboard Replacement, Battery: 7 단계, 이미지 2/3 Asus Chromebook C202 Motherboard Replacement, Battery: 7 단계, 이미지 3/3
    • Pull the latch out on both the Input/Output board as well as the motherboard.
    • Gently remove the ribbon cable connecting the I/O board to the motherboard.
  8. Asus Chromebook C202 Motherboard Replacement: 8 단계, 이미지 1/3 Asus Chromebook C202 Motherboard Replacement: 8 단계, 이미지 2/3 Asus Chromebook C202 Motherboard Replacement: 8 단계, 이미지 3/3
    • Remove two 4 mm Phillips #1 screws from the metal grate connected to the battery.
    • Remove metal grate from battery.
    • Remove six 4 mm Phillips #1 screws from the battery
  9. Asus Chromebook C202 Motherboard Replacement: 9 단계, 이미지 1/2 Asus Chromebook C202 Motherboard Replacement: 9 단계, 이미지 2/2
    • Disconnect the battery from the motherboard.
    • Lift battery from the bottom portion of the Chromebook.
  10. Asus Chromebook C202 Motherboard Replacement: 10 단계, 이미지 1/1
    • Remove the battery from the Chromebook.
  11. Asus Chromebook C202 Motherboard Replacement, Motherboard: 11 단계, 이미지 1/1
    • Unscrew one 3 mm Phillips #1 screw.
    • Unscrew one 2.5 mm Phillips #1 screw.
    • Unscrew four 4 mm Phillips #1 screws.
  12. Asus Chromebook C202 Motherboard Replacement: 12 단계, 이미지 1/2 Asus Chromebook C202 Motherboard Replacement: 12 단계, 이미지 2/2
    • Disconnect the wires that connect the motherboard to the speakers.
    • Disconnect the motherboard from the display.
  13. Asus Chromebook C202 Motherboard Replacement: 13 단계, 이미지 1/1
    • Lift the motherboard up and out of the chassis.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Christopher Segale
회원 가입일: 09/28/16
883 평판
안내서 6개 작성하였습니다
USF Tampa, Team 3-1, Passmore Fall 2016 USF Tampa, Team 3-1, Passmore Fall 2016 회원
USFT-PASSMORE-F16S3G1
4 회원들
안내서 16개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 20
30일 전: 64
전체 시간: 2,525
