소개
The daughterboard is an extension of the motherboard. The daughterboard is connected to the USB drive, so when you plug into the USB compartment, the daughterboard communicates with the motherboard. This guide will show how to remove the daughterboard/USB piece.
필요한 것
Turn the device over so the bottom is facing up.
Remove the ten Phillips #1 8.0 mm screws.
거의 끝나갑니다!
결론
