주요 콘텐츠로 건너뛰기
Asus Chromebook C202SA-YS02 Touch Pad Replacement
필요한 것
  1. Asus Chromebook C202SA-YS02 Touch Pad Replacement, Palm Rest: 1 단계, 이미지 1개 중 1개
    • Turn the device over so the bottom is facing up.
    • Remove the ten Phillips #1 8.0 mm screws.
  2. Asus Chromebook C202SA-YS02 Touch Pad Replacement: 2 단계, 이미지 2개 중 1개 Asus Chromebook C202SA-YS02 Touch Pad Replacement: 2 단계, 이미지 2개 중 2개
    • Carefully use the plastic opening tool to pry the palm rest apart from the bottom cover. Start from one spot and systematically work your way around until the whole palm rest is detached.
  3. Asus Chromebook C202SA-YS02 Touch Pad Replacement: 3 단계, 이미지 1개 중 1개
    • Disconnect the two cables that run from the keyboard to the motherboard and from the touch pad to the motherboard.
    • You may have to use a spudger to lift open the respective latches.
  4. Asus Chromebook C202SA-YS02 Touch Pad Replacement, Touch Pad: 4 단계, 이미지 1개 중 1개
    • Gently peel off gold tape.
  5. Asus Chromebook C202SA-YS02 Touch Pad Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the three Phillips #1 3.5 mm screws located on the under-side of the palm rest.
    • You can now pop out the touch pad.
결론
작성자
1다른 기여자 명과 함께
Beau Hansen
회원 가입일: 09/28/17
845 평판
안내서 7개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 31
전체 시간: 1,489
