소개
The touch pad (also called the track pad or mouse pad) is a component of the palm rest assembly. If only your touch pad, and not the entire palm rest assembly (i.e. keyboard) need replaced, then use this guide.
필요한 것
Turn the device over so the bottom is facing up.
Remove the ten Phillips #1 8.0 mm screws.
거의 끝나갑니다!
결론
